Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Tune up and headlights
Old May 23, 2012 | 06:55 PM
s0biek's Avatar
Icon2 Tune up and headlights
Greetings all!
Recently, I purchased a halo projector headlights for my 2007 honda civic. My mechanic successfully installed them however, he didn't replace the bulbs with white bright ones ( I'm looking at the sylvania silverstar ones ) . I was just wondering if anyone here would know which model will fit into the projector headlights and if it is SAFE to replace them with sylvania silvertar. Today I asked someone at NAPA parts store and he said the model is for the bulbs is H7 but isn't 100% sure.
Also, I'm looking forward to do a tune up and I was wondering if I should have my transmission oil changed and which oil is safe to put in. My car has 43K miles now and manual transmission.
If anybody could shed some light..
Thanks!!!
Old May 24, 2012 | 07:11 AM
420Coupe's Avatar
Default Re: Tune up and headlights
your lights are High beam 9005(DRL) Low Beam 9006. Stick to factory honda transmission fluid, they have a new re-engineered formula, black with green label. i believe transmission may be red label not 100 %.
Old May 28, 2012 | 06:26 AM
Blk06Si's Avatar
You won't need a tune up until 105k miles. Replace your MTF if it wasn't changed at 30k miles and always use Honda OEM fluids.
Old May 28, 2012 | 12:10 PM
s0biek's Avatar
Thank you both for the help. I will check with my mechanic and go ahead and change the transmission oil.
Again, Thanks!
Old May 30, 2012 | 01:18 PM
vladd's Avatar
When installing the new headlights, did you reuse the original bulbs, or did the new headlights come with their own? Aftermarket headlights will sometimes come with different types/sizes of bulbs, so getting the type of bulb that the OEM headlights come with wouldn't help you with the new headlights.
carid
Jan 26, 2017 05:15 AM
Bashismashi
11
Sep 28, 2012 02:06 PM
s0biek
Jun 1, 2012 03:23 PM
96CivicEXSedan
14
Oct 4, 2011 09:24 PM
hcivic99
Jan 28, 2009 09:34 AM
