ARP rod bolt will not torque, keeps spinning
Old May 23, 2012 | 12:43 PM
pushinlsteg's Avatar
Default ARP rod bolt will not torque, keeps spinning
This is a straight turbo LS setup.
Just a little history here, I haven't put a motor together in about 5 years due to my career. 5 years ago when I put this motor together (and blew it up) I noticed when I was putting my rods in, all of the bolts torqued fine except for one single bolt on #2. So with the intentions of not giving a **** I went ahead and left it, even though it didn't torque. I did not check the stretch or anything like that it was a very much throw it together setup, car was only $500.. etc
So it ran for about 2 months turbo'd on a SC61 on 18 psi on pump gas to 9000 rpm daily, finally I melted a piston and cracked a sleeve(detonated, fuel pump took a ****).
So I got some new ARP rod bolts, and im sitting here with a decision, do I buy a new set of rods, or figure out this #2 rod situation?
I have the OLD eagle rods with the small 5/16 arp bolts, I got brand new bolts ready to go in, but what do you think the issue is or the problem is? like I said it revved to 9000 rpm without any issues without hearing the *click* on the torque wrench last time.
this is going to be a stock sleeved b18a block, with block guard, forged piston/rod setup with a worked LS head with valvetrain, on maybe 15 psi on the same sc61 on pump gas.
thanks to any machinist with info
Old May 23, 2012 | 12:49 PM
Dc4LsTeG's Avatar
EK9
Default Re: ARP rod bolt will not torque, keeps spinning
I dont understand your problem. Put the new bolts in and make sure they torque correctly
Old May 23, 2012 | 01:07 PM
Last time I put in new bolts, it did not torque down, on one side of the cap on #2 connecting rod. I dont think its going to torque this time either, basically do you think somethings wrong with the threads on that side of the rod, should I waste $$ getting it checked over, or just throw it together because it lasted last time, or get a new set of rods, even though I already bought brand new bolts for these rods. I dont understand why 7 bolts torqued to spec just fine and the one will not torque, it keeps turning and turning and turning after it should click on the wrench
Old May 23, 2012 | 01:28 PM
Dc4LsTeG's Avatar
EK9
Yea id get it checked out. Are you sure you had the right size bolts?
Old May 23, 2012 | 02:55 PM
civicmike98's Avatar
You tore the thread right out of the rod. Replace the rods. You might be able to timesert it. Not really a fan of helicoil for this application.
Old May 23, 2012 | 03:03 PM
yeah I ordered them from eagle.
Old May 24, 2012 | 02:06 AM
rich7777's Avatar
Try a different bolt as the bolt maybe bad.
rich7777
Mar 1, 2010 07:43 AM
LSVtechnologytur...
Jul 14, 2008 07:39 AM
EnzoSpeed
Sep 22, 2005 03:20 PM
DRAGLS
Feb 5, 2004 01:22 PM
FastFoot
Sep 28, 2002 12:09 AM
