92 turbo gsr engine harness question
Old May 22, 2012 | 05:48 PM
Mike52109's Avatar
Default 92 turbo gsr engine harness question
I have a turbo 92 gsr da. The motor is a 94 head with a 99 block. Could I use a 94 gsr harness in mine or no because my harness is butchered and I found another for a good price.
Old May 22, 2012 | 09:02 PM
kchungb17a's Avatar
Default Re: 92 turbo gsr engine harness question
So to clarify, you have a DA with a USDM B18C1?
You should be able to use a 94 GSR harness but some of the sensors on your 99 block won't be used. At least the crank angle sensor behind the lower timing cover. No problem, just leave it unplugged. Also you will need an OBD1 distributor. If you're running the OEM manifold with IAB, you should have an OBD1 P72 ECU.
Old May 28, 2012 | 06:46 AM
Mike52109's Avatar
Ok I'm currently working on getting a ecu the one that cake with it is a tuned ls ecu and the car runs like crap. I appreciate the help.
jhojhet
May 28, 2011 07:08 AM
spinney
Jul 28, 2005 12:50 PM
hallsy
Feb 8, 2004 04:26 AM
slowhatch4now
Sep 19, 2003 06:28 AM
Phoenix GSR
Mar 12, 2002 11:45 PM
