injector question
im not sure if that ecu will work...just for curiosity sake...is your O2 sensors working? you do have a upstream & downstream set-up right? im just taking an educated guess now... only other option is to google your situation & proceed from there... good luck man.
almost forgot.. check your injectors & see if they're high or low impedance .. could fry your injector drive in your ecu if ya get that fouled up... you may need to put injectors from engine you scored the ecu from.. and yes im on a learning mission myself here... hope this helps you
MintFlavored
Nov 2, 2002 07:30 PM
