clutch change issue
Old May 21, 2012 | 03:53 PM
Vash121991's Avatar
Default clutch change issue
sup HT.
just put a clutch in my 91 ef sedan stock tranny w/ d15b vtec
got clutch changed fine.
tranny went back on easy.
the only issue i am having is the clutch pedal has no tension, it goes right to the floor, im really hoping i dont have to drop the tranny again, might it be the clutch cable? are me not installing the clutch cable right?
thanks for your reply in advance,
Old May 21, 2012 | 03:56 PM
Spug's Avatar
Default Re: clutch change issue
Post a pic of the clutch cable connected to the tranny.
90_EX_Civic's Avatar
going to have to adjust the cable. i don't remember off the top of my head so you're going to have to mess with it to figure it out.
Old May 21, 2012 | 03:59 PM
Vash121991's Avatar
been messing with it for 2 hours, and i can take pics in a bit, its dumping rain atm, but it almost feels like the cable is too long now, i am clueless lol.
Old May 21, 2012 | 04:19 PM
EG1PJT's Avatar
Have someone push on the pedal and make sure that the cable is being moved at the tranny.
Old May 21, 2012 | 06:24 PM
93delsold16z6's Avatar
ya you have to spin the plastic **** on the slave cylinder. tighten it by turning it to the right. I had same issue. Tightened it, and fixed
Old May 21, 2012 | 09:42 PM
Vash121991's Avatar
the cable is moving the clutch fork arm, it just had alot of play. im dropping the tranny in the morning, i suspect i didnt tighten the throwout spring?
Old May 22, 2012 | 12:47 AM
Spug's Avatar
You remembered to put in the throwout bearing, right?
2x0
Transmission & Drivetrain
Jul 7, 2017 06:30 PM
BLKHB89
Apr 12, 2008 08:17 AM
lilo_goki
13
May 9, 2007 10:34 AM
92TEGGYGSR
Jun 7, 2004 04:19 AM
.nate
Sep 12, 2002 12:47 PM
