Fuel leak, HELP!
Old Oct 13, 2002 | 06:40 PM
bikeboy80's Avatar
Default Fuel leak, HELP!
I have a small fuel leak comming from the bottom of my fuel filter. Aperntly it has been leaking for awhile, now before you flame me, its not alot, i noticed a little "sludge" coating the fuel line.
now after some testing, it only leaks right when i turn the car off, seems to be caused by the higher pressure of the line at that moment. it does not leak a drop at all while driving. i was thinking of trying to wrap some teflon tape around the threads of the fitting at the bottom of the filter to stop it
any other sugestions? thanks
Old Oct 13, 2002 | 06:41 PM
Pepsi90919's Avatar
Default Re: Fuel leak, HELP! (bikeboy80)
um, buy a new one? they're like 10 bucks for me
Old Oct 14, 2002 | 08:44 AM
bikeboy80's Avatar
Default Re: Fuel leak, HELP! (Pepsi90919)
sorry maybe i wasn't clear enough, the filter itself isnt leaking, the fitting at the bottom of it is. I took it apart this morning and everything seemed fine, put it back together and now it leaks worse
one question, is there a rubber gasket that should be in this fitting? mine does not have one. if there is then that would be my problem
Old Oct 14, 2002 | 10:20 AM
Pepsi90919 pt2's Avatar
fitting at the bottom...hrm, mine are at the top. i guess it's a different design.
but there are 4 brass washers, nothing rubber.
Old Oct 14, 2002 | 10:42 AM
raene's Avatar
Default Re: Fuel leak, HELP! (Pepsi90919 pt2)
No, there are no rubber gaskets, yes, there are 4 brass rings, and yes, you should use teflon tape. Just be careful not to get too happy with that stuff and put too much on or some can break off and get into your fuel stream.
Old Oct 14, 2002 | 03:51 PM
bikeboy80's Avatar
Default Re: Fuel leak, HELP! (raene)
well it seems that the piece of tubing that goes to the filter fitting wasn't flaired perfect and thus it leaks, hmmm wonder who did that
tronic
Aug 31, 2016 02:57 PM
ODbuilt
Apr 26, 2014 12:50 PM
hondachris1994
Jul 30, 2007 12:06 PM
Hi-Tech Honda Girl
Mar 25, 2007 09:47 AM
92blackg2
Feb 28, 2005 04:44 PM
