precision 62/65 vs 67/66 cea
Old May 21, 2012 | 12:56 AM
whitevteckiller's Avatar
Default precision 62/65 vs 67/66 cea
hi guys!i will select turbo precision!my question is the best for my project(b18c) with 10/1 compression is 62/65 cea ball bearing or 67/66 ball bearing!the selection of turbos is cea new code! my project is for 700-750 whp hight boost in dragster and 600 whp on the road!!
Old May 21, 2012 | 01:26 AM
Ron Burgandy's Avatar
Default Re: precision 62/65 vs 67/66 cea
fail.
Old May 21, 2012 | 02:57 AM
why?is very big turbo??
Old May 21, 2012 | 07:02 AM
paulzy's Avatar
They can both make that power but the 62 is a ton cheaper
Old May 21, 2012 | 07:14 AM
meane30's Avatar
If you are only looking for 700-750 go with the 6265. It's a lot cheaper
Old May 21, 2012 | 07:16 AM
KeseK24RSX's Avatar
A 6266 will get you to 800whp. No need to go w/ a 67mm.
We are currently making 655whp using a 6266 w/ .82 a/r on 26psi.
-Marquis
-KMOD Performance
Old May 21, 2012 | 01:30 PM
CDecker0218's Avatar
6265
Old May 21, 2012 | 01:48 PM
d16z6Tcrx's Avatar
Both are great. Ran a 6262 and a 6766. Both made great power. The 6766 makes over 700 effortlessly on my stock sleeve 1.8l. Makes somewhere near 20whp per psi over 20psi with very little timing.
Old May 21, 2012 | 01:52 PM
sportfwddc2's Avatar
6785 or your just wasting money ;P
Old May 21, 2012 | 02:34 PM
sanman000719's Avatar
6265 here .80/1.15 t4 frame
757@34psi on pump e85
this is a 84.5 b16a2
Old May 21, 2012 | 07:20 PM
ralph11sec's Avatar
any idea on what power range would a 6266 T3 .63 a/r do on a 1.8L motor E85?
Old May 21, 2012 | 09:37 PM
Boosted_01 R's Avatar
why do want the 6265 ? get the 6266CEA and call it a day 6766CEA is over kill
Old May 22, 2012 | 03:55 AM
94lsvturbo's Avatar
no the same turbo but we made 710 on a t3 6262 @ 34psi & E85 with a very simple setup. i think the 6266 would be good for a street car/ weekend warrior.
Old May 22, 2012 | 04:57 AM
d16z6Tcrx's Avatar
I ran a 6262 .63 on my same 1.8l last year and made 550@ 21 psi on vp import. The .63 seemed to start to choke up at that point which is why i ended up switching to an .82 housing on a bigger turbo. I suggest if looking for more than 600 get an .82.
Old May 22, 2012 | 06:31 AM
Do-Work's Avatar
is that a twin scroll setup?
Old May 22, 2012 | 08:18 AM
turbo is twin the topmount is open
Old May 22, 2012 | 12:11 PM
Do-Work's Avatar
that's good power for a little b16, what's the setup?
Old May 22, 2012 | 01:03 PM
DA 4 Lyfe's Avatar
I made 720whp 514tq at 35psi on a t4 twin scroll bb 6265 1.15 ar.
Has anyone done any testing on the new CEA 6262's? I was thinking about swaping out the turbos to gain spool time and still make the same power
Old May 22, 2012 | 03:39 PM
84.5mm rss b16a2/stock p72 head with gsr cams/t1 cam trigger/cop/m&w pro14/redline t4 topmount open/6265 1.15 devided housing/id2000's/kings coated bearings/aemt 1:1 regulator/stock return/-10 feed/aeromotive pro series pump/sumpr stock tank/aem ems v1
cp/eagle
Old May 23, 2012 | 03:30 AM
fo0's Avatar
fo0
6766 is only $180 more than 6266
Old May 23, 2012 | 05:37 AM
Do-Work's Avatar
for what your trying to do the 6266 will be ideal for your goals and street use.
Old May 23, 2012 | 11:23 AM
my buddy has a b16 with a 6262 and made 595whp tuned by Cortney Green in Utah.
1lowek2007
Dec 5, 2012 06:53 PM
GEN2 LS
Dec 15, 2010 04:45 PM
loserface
Oct 21, 2004 10:21 PM
H1PNOT1C PRELUDE
Feb 9, 2004 07:49 AM
mafioso102
Jan 14, 2004 10:02 AM
