Transmission & Drivetrain Gearboxes, Differentials, Clutches
New slave cylinder problem
Old May 20, 2012 | 10:01 AM
JustaEgg's Avatar
Default New slave cylinder problem
Ok first some background. The car is a b18b with a ls cable tranny. I put a new slave cylinder on and my clutch has no pressure, goes completely to the floor, but if I crack the bleeder screw on the slave its a steady stream of brake fluid. Sat here pumping the pedal for 10 minutes, still no pressure. I can feel the fluid moving through the lines of somebody else pumps the clutch, but the slave cylinder doesn't move the clutch lever at all. I know how to bleed the slave cylinder but seems kinda useless because it seems like no air comes out, just a steady stream of fluid.
Old May 20, 2012 | 12:12 PM
Gunmetal_B20_Hatch's Avatar
Default Re: New slave cylinder problem
cable tranny doesnt have master/slave cylinder... I am confused.
Old May 20, 2012 | 02:23 PM
JustaEgg's Avatar
If you put a cable tranny in a car that's set up for hydro, instead of the cable pulling up on the clutch arm the slave cylinder sits below it and pushes up. So although it was originally a cable tranny its converted to hydro.
Old May 23, 2012 | 08:13 PM
B and B's Avatar
Loved
Community Favorite
New cylinder could be defective?
dazebreak
Oct 22, 2013 11:42 AM
dkrex001
Jan 26, 2007 02:22 PM
MarksIntegra
Dec 22, 2006 07:02 AM
TuwboBuddy
May 3, 2006 07:40 PM
91_hatch_si
Jan 5, 2003 07:38 AM
