Motor - Hot start
Old May 19, 2012 | 05:47 AM
Bollie's Avatar
Default Motor - Hot start
Hi folks,
I am bit desparate with my Honda HF1211 lawn mower (motor GXV340).
The motor starts without any problem when it's cold but starting it hot simply doesn't work. I checked for any oil leakage but that doesn't seem to be the case. As soon as the motor has cooled down, starting is OK again.
Anyone here who has a clue about this?
Many thanks.
Bollie
Old May 19, 2012 | 08:32 AM
civickiller's Avatar
Default Re: Motor - Hot start
maybe its a main relay kind of case
Old May 19, 2012 | 12:45 PM
Bollie's Avatar
If it would be a relais problem, what is the way to figure this out?
Old May 19, 2012 | 01:53 PM
i didnt mean relay's specifically but wire soldered joints which could relay's, switches, etc
Old May 19, 2012 | 11:52 PM
Bollie's Avatar
Could it be an air filter issue? Or would you expect that the cold start would then be a problem as well in every case?
Old May 20, 2012 | 05:54 PM
Perfectionist's Avatar
A clogged up filter can cause an over-rich condition that will make hot starting difficult. Clean/replace the filter. The next time it won't start when hot, check for spark. If no spark, the ignition coil could be on it's way out. Make sure there isn't a safety switch that is getting hot enough to expand the contacts with too tight clearance between them.
Otherwise, could be a carb gasket leak, or the cab needs cleaning/adjusting, or too much ethenol in the fuel.
Old May 20, 2012 | 06:08 PM
LocoJoe's Avatar
I had the same problem. When cold worked fine, hot died on me. It was the ignition coil. Repleced and problem solved.
Old May 26, 2012 | 04:14 AM
Bollie's Avatar
Hi Perfectionist,
No sparks when starting hot!
So I guess I better replace the ignition coil. I don't think there is any safety switch on this GXV-340 motor (can't find any in the manual).
Old Jun 9, 2012 | 03:38 AM
Bollie's Avatar
Hi guys,
I just replaced the ignition coil as some of you suggested.
Guess what; cold start went easily. Hot start ... problems again; no sparks.
When I stop the motor after running for 10 minutes and wait for about 10 seconds, restart usually doesn't work. However, when I restart it immediately (so without waiting the 10 seconds), the succes rate seems higher.
This problem is really driving me crazy.
Any further ideas or explanations?
Old Jun 9, 2012 | 06:04 AM
Bollie's Avatar
Hi,
By the way, when starting, the motor makes a weird noise during the first few seconds.
See or hear for yourself below (between seconds 10 and 13).
This was one of the few successful hot starts.
http://youtu.be/7-b0ox5J-7Q
Old Jun 10, 2012 | 11:12 AM
Bollie's Avatar
Anyone with a clue about this weird sound (see video)?
Could a small starter solenoid produce such a loud noise?
Or would it be the starter engine causing the problem?
Old Apr 5, 2023 | 06:16 AM
qqq121212's Avatar
hello everyone, read here https://upgrade4house.com/why-does-m...tart-when-hot/, it helped me, good advice
whitehf
Dec 12, 2011 07:00 PM
super jdm yo
Apr 7, 2007 04:10 PM
spence19
Jul 23, 2006 02:45 PM
kitkatR
Oct 31, 2004 07:15 PM
