Is Euro-R intake manifold obd2 compliant?
Old May 17, 2012 | 10:30 AM
sive's Avatar
Default Is Euro-R intake manifold obd2 compliant?
I'm converting a euro-r to obd2 (for emissions purposes). Can i keep the intake manifold. injectors are saturated, and the obd2 aicv plate it needed. The only major difference i know of is the spray pattern. If I don't need to swap it what about the map sensor..I plan on using p5m.
Old May 17, 2012 | 12:31 PM
TheJGB3's Avatar
Default Re: Is Euro-R intake manifold obd2 compliant?
For ODBII compliance you will need to use the EGR setup thats already there. One nice thing about the Euro-R manifold is the removable EGR plate instead of the EGR ports so cleaning them is really easy.
Old May 17, 2012 | 12:42 PM
apexi_bb6's Avatar
The problem I came across was tunning. It really needs that to run right, and if you are using the EuroR injectors and rail Im not sure if a vafc would be sufficient (someone correct me if Im wrong). I was looking at EManage at first but since my state is non emissions compliant ended up with Hondata. If you keep the usdm injectors I dont think they bolt in properly. I would talk to Roskoracing about that he makes adapters for different injector/rail configurations. I ended up with his EuroR manifold and RDX injectors and his rail. However that rail is in the way of the egr valve. He offers 2 "Block-off" plates for the egr, one for the valve itself and one that covers the ports. He told me that the second could be used with an egr valve to maintain its use.
http://www.roskoracing.com/Euro_R_Manifolds.html
Email him (Shawn) and he gladly answers any questions and ships what he has in stock quickly. He's been a huge help getting my project going. Im just waiting to send my block to the machine shop.
jesse.pulido
Jun 29, 2013 04:57 AM
UrbanDiplomat
Mar 27, 2013 02:34 PM
GsrRussell
Apr 14, 2008 11:34 AM
xtal
Sep 17, 2003 03:46 PM
austrian type-R
Oct 3, 2002 09:43 AM
