typr r cams with adjustable camgears what degree
Old May 16, 2012 | 04:54 PM
x-s-i-v's Avatar
Default typr r cams with adjustable camgears what degree
i know the car should be degreeded and tuned. for this but i just need it as a referance
what is the general adjustments for type r cams used in b series turbo with adjustable cam gears.
intake +1 deg
exhust -2 deg
somthing like that??
thanks guys
Old May 16, 2012 | 05:40 PM
turbociv910's Avatar
Default Re: typr r cams with adjustable camgears what degree
they should be 0-0.
Old May 16, 2012 | 06:54 PM
jdm inc's Avatar
Originally Posted by turbociv910
they should be 0-0.
x2
Old May 16, 2012 | 07:04 PM
Turbo-LS's Avatar
advancing your intake and retarding the exhaust will give you more overlap and will not improve performance with forced induction. leave them at 0 and 0 or tune on the dyno starting with intake cam being retarded and then exhaust cam being advanced.
Old May 17, 2012 | 02:30 PM
ryguy2588's Avatar
Just use stock cam gears.
Old May 18, 2012 | 03:05 AM
blackeg's Avatar
Or leave the aftermarkets at 0-0. Im at 0-0 making about 500hp with itr cams. Don't mess with it unless u are on the dyno.
Old May 20, 2012 | 10:02 PM
x-s-i-v's Avatar
sorry, they are adjusted already from a dyno. i took them off the cams, now im tripping out on what cam they came off. ive marked them. i and x. but are just worryed i got it muddled up.
one is adjusted + and one -
Old May 21, 2012 | 11:56 AM
shawty22's Avatar
I would assume the - is exhaust and + is intake. I have itr cams and we retarded the exhaust and left the intake as it was.
Old May 21, 2012 | 12:55 PM
FRernesto's Avatar
Leave them at 0 and 0.
Old May 21, 2012 | 05:32 PM
vwbased's Avatar
have a nice day
Old May 23, 2012 | 05:54 AM
B and B's Avatar
Loved
Community Favorite
Originally Posted by vwbased
changing valve tip height will change the timing.
I was wondering about this when the machinist grinds the tip during valve job.
I was thinking adjusting the lash made up for it, but yeah..then it will come on the ramp later, I guess. Is this enough to warrant adj. gears? Cuz I'm running stock.
Do they always dress the tips? And how do u measure this? With a dial indicator? Would this be the "installed height" spec? Seemed hard to find a flat surface to measure that as I think back...obviously don't do this very often, but have another build in the works so...just asking
Didn't mean to take ur thread somewhere else, man...just made me wonder.
Old Aug 7, 2012 | 05:06 PM
x-s-i-v's Avatar
all good rung the tuner and got the crrect degree setting of the computer and the last tune
teg_racer
Jun 20, 2010 08:36 AM
Redsun
Aug 30, 2004 06:23 AM
saso
Sep 27, 2003 07:52 AM
NVBAM
May 21, 2003 09:00 AM
bananacruzier
Feb 4, 2002 05:52 AM
