Optimum placement of a dry N2O nozzle?
Old Oct 13, 2002 | 04:22 PM
n2ohuffer's Avatar
Default Optimum placement of a dry N2O nozzle?
I know these forums seem to be kinda turbo biased, but I was wondering where I should tap the spray into? I know the intake tube (haha), but before I go drilling my Iceman full of holes, is closer to the throttle body better? I have it about 10 inches down the piping now, about 2 inches on the filter side of the ambient air sensor. It runs fine with no detonation, but I want to know if closer is better...
Old Oct 14, 2002 | 03:09 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Optimum placement of a dry N2O nozzle? (n2ohuffer)
I'm using 18" from TB with my ZEX kit.
Check the sig.
Old Oct 14, 2002 | 04:40 PM
Jeff C's Avatar
Default Re: Optimum placement of a dry N2O nozzle? (Mista Bone)
that seems awful far. any idea what happens if you moved it closer.
personally id do direct port
Old Oct 14, 2002 | 04:47 PM
civichb97's Avatar
Default Re: Optimum placement of a dry N2O nozzle? (Jeff C)
12 to 15 inches from the TB is the best place for it. From what I have seen and read.
Old Oct 15, 2002 | 03:47 AM
Mista Bone's Avatar
D Tranny Guru
closer means some cylinders get more nitrous that other cylinders. On a dry system this is bad news.
Old Oct 15, 2002 | 03:53 AM
dirtySOHC's's Avatar
does this go the same with a wet set-up
right now mine is about 8-9 in. from the TB but i turned the noozle towards the filter, dont know if thats a good idea or not?
Old Oct 16, 2002 | 12:09 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Optimum placement of a dry N2O nozzle? (dirtySOHC's)
Honda intakes won't flow a wet single fogger very well. Fuel dropout is a issue.
Dry to 75 shot, 4 port wet afterwards is the best bet.
Old Oct 16, 2002 | 12:43 AM
NXSpoon's Avatar
right now mine is about 8-9 in. from the TB but i turned the noozle towards the filter, dont know if thats a good idea or not?[/QUOTE]
No, it isn't. The nozzle should spray towards the TB.
As for distances: (From ClubSi, "civicsidude") DRY SHOT: about 6 inches from the TB. If you have an AEM, use the oil return hole.
WET SHOT: About 2-3 in. and try to point it towards the runners to get the fuel in there.
Integra99GSR
Jul 9, 2016 08:29 PM
memic
Apr 3, 2005 07:28 AM
milton
May 6, 2004 04:43 AM
usdm420
Apr 29, 2004 12:02 PM
BLUE EH3
Dec 18, 2003 03:16 AM
