vtec wont work on my b16a in 94 dx
Old May 13, 2012 | 08:10 PM
hondabro1988's Avatar
Default vtec wont work on my b16a in 94 dx
I got a b16a genII in my 94 civic dx with a chipped ecu, intake, header back to apexi n1 exhaust. lowered . If i hook vtec up to a switch you can hear it but if i hook it up straight to the ecu u dont hear it at all. what could be my problem? plus im throwing a code13 for a chipped ecu.(from phearable.net) can anyone help me out?
Old May 13, 2012 | 08:12 PM
joiv21's Avatar
Default Re: vtec wont work on my b16a in 94 dx
whoever chipped your ecu didnt do a very good job it looks like
Old May 13, 2012 | 09:27 PM
y u say that? even tho the code is there vtec will work as a switch not the normal way
Old May 13, 2012 | 09:56 PM
turbohatch96y7's Avatar
When you apply a direct 12v positive to your vtec solenoid you are energizing the coil allowing oil pressure to lock your rocker arm and using your vtec lobe on the camshaft...BUT your ecu is not changing from the low map to the high map.. pretty much leaning out your engine from the added air but lack of fuel.
Make sure your speed sensor is working,oil level, and ec is chipped properly.
Old May 14, 2012 | 06:12 AM
yes all that is good. could my map sensor be bad or tps?
y would i throw code 13 then,
Old May 15, 2012 | 02:48 PM
EGyoke's Avatar
If you can hardwire vtec to a switch, then it doesnt work when hooked to your ECU, its your ECU. Try a different ECU. MAF/TPS would cause misfires and not just a CEL. Did you research the code and see what others have had trouble with similar in the past? Are you using a jumper harness? Any frays/tears? Disconnected pins? You have to go through the trouble shooting process and eliminate everything that works and doesnt work.
hondabro1988
May 28, 2012 10:50 AM
hondabro1988
May 14, 2012 06:14 AM
B Dap
23
Dec 13, 2009 08:47 AM
IVI
Aug 26, 2004 06:50 AM
ScrapinSi
Aug 28, 2002 11:33 AM
