Problems with my D16Z6....bogging
Old May 13, 2012 | 05:43 PM
carlosd68's Avatar
Default Problems with my D16Z6....bogging
The car idles perfect, and no check engine.
The only thing I have noticed is wrong is the transmission Input Shaft Bearing because when the clutch is not pressed in it sounds, and when I press the clutch the noise goes away.
I am trying to figure out why the car boggs......it does not have full power.....once it gets to 3K it takes forever to get higher in RPMS....sounds like the engine is working too hard........Its like bogging or something.......any ideas what it could be?
Old May 16, 2012 | 07:51 PM
carlosd68's Avatar
Default Re: Problems with my D16Z6....bogging
182 views and no bumps......help me out
Old May 17, 2012 | 02:33 AM
grumblemarc's Avatar
The Grumpiest
Tune up.
Old May 17, 2012 | 03:05 AM
jbpnoman's Avatar
Plugs, wires, cap, rotor, ignition and mechanical timing, air filter, fuel filter, oil change.
If you're too stingy to just replace it all like you probably need to, go buy/rent a timing light to check your ignition timing, use your eyes to check the mechanical timing, and then check your spark plugs. They should all be giving off a white spark.
Old May 17, 2012 | 06:09 PM
carlosd68's Avatar
I bought the car and it wouldn't turn on. I did the timing belt change, water pump and tensioner. Also changed the oil and spark plugs.
Car sounds perfect when it is at idle....but it runs like ****! Changed the rotor and cap today. and did not change anything
It could be my ignition timing
Old May 17, 2012 | 06:17 PM
The Grumpiest
Then check it AND your mechanical timing while you're at it. And changing oil and spark plugs does not constitute a tune up.
Old May 17, 2012 | 07:06 PM
carlosd68's Avatar
will do thanks
Old May 17, 2012 | 07:12 PM
roc0487's Avatar
Injectors, I had a teg that ran like complete *** and I had to take hills in 2nd gear... turned out the injector was bad... with the car idling (carefully) pull each spark plug one at a time to find which cylinder(s) DOESNT change how the car idles... That will point you to the weak cylinder, from there it is either fuel/spark/ or air.
o2 sensor, even without a CEL sometimes the wiring gets corroded or the sensor itself is gummed up...
Cat, if it is clogged you won't have much flow...
Just some ideas to add to what others have mentioned... hope it helps.
Old May 17, 2012 | 07:14 PM
roc0487's Avatar
Forgot to mention to pull distributor cap, check coil and coil spring... And make sure your plug wires are in the right order!
Old May 21, 2012 | 06:43 PM
carlosd68's Avatar
thanks ROC0487.........i am getting ready to give up.....did a full tune up ......Plugs, wires, cap, rotor, ignition and mechanical timing, air filter, fuel filter, oil change...
Car still running like ****......i will have to check the injectors and 02 sensor
Old Sep 28, 2012 | 04:51 PM
carlosd68's Avatar
car is still bogging....anything else I can do?
Old Sep 28, 2012 | 07:59 PM
roc0487's Avatar
Have you diagnosed all of the above mentioned possibilities?
Old Sep 28, 2012 | 08:07 PM
10psiLsEf2's Avatar
THIS^ timing would be my first place to look into!
coolswimmerjon
Sep 3, 2011 07:43 AM
kevbo06
Apr 26, 2010 12:31 PM
Turbo_y8
May 24, 2005 07:06 AM
boostedcivichatchbacksi
Sep 21, 2004 11:56 AM
b16awarrior
Oct 29, 2002 07:56 AM
