Timing belt came loose during driving, car wont start after adjusting
Old May 13, 2012 | 02:03 PM
[713]'s Avatar
Default Timing belt came loose during driving, car wont start after adjusting
Recently while driving, my timing belt slackened up and i could tell cuz the belt was slapping around and i looked at it doing that, and left me stranded. i managed to get the car home to check it out, sure enough the belt got really loose, so i made the necessary adjustments, re-tensioned, checked timing and whatnot, but the car just wont start. even before this i noticed every time id start my car it was pretty noisy and rough, made a scratching noise. im assuming its the starter itself, but not really sure though. anyway, i try cranking but it wont start anymore and idk what else to check. been looking at my haynes and trying to isolate as many things to find out what it else but im stumped. please help i need my car as im starting school soon. ill try to put up a sound clip so you guys can hear what im talking about
Old May 13, 2012 | 08:07 PM
type_r_ek's Avatar
Default Re: Timing belt came loose during driving, car wont start after adjusting
h0w did y9ou check timing without it started, do you have the crank at tdc for cyl 1 and the cams in the proper postion? did you bend any valves or have head damage.
Old May 13, 2012 | 08:31 PM
[713]'s Avatar
well before the car did this, i checked timing about a month ago during maintenance, thats how i did it.
anyway, no valves are bent and there's no sign of head damage.
i checked the dizzy, and starter, both were fine, but i noticed that i had some oil on my spark plugs on 3 and 4 cylinders. i cleaned them and put everything back together. tried to start again, but no dice. the car seems to struggle to start, and there was some smoke coming out from the intake manifold, plus a little hum/ring around the throttle body. dont know what that is. im going to keep researching for the mean time and hopefully someone here can help me out.
Old May 14, 2012 | 02:31 PM
[713]'s Avatar
bumpin in case anyone can help me out on here
Old May 14, 2012 | 02:44 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Hate to be the bearer of bad news, but it sounds like there's a 99% chance you bent some valves and messed up your head when you were cranking on it.
Your best bet is to pull off the head and check it out.
Old May 14, 2012 | 03:23 PM
[713]'s Avatar
damn i was just thinkin the same thing actually...
oh well, i planned on swappin out the motor anyway since this ones been pushin 200k miles. ill check em out thanks
ddn1313
Aug 4, 2018 02:46 PM
VanHonda
Dec 7, 2006 05:38 PM
DaKINE-Ek
13
Aug 15, 2006 10:57 AM
djtony5
May 5, 2006 09:52 PM
msn
Jul 15, 2005 07:49 AM
