wont idle. trouble starting. oil in plugs?
Old May 13, 2012 | 01:45 PM
boost4life1's Avatar
Default wont idle. trouble starting. oil in plugs?
Starts and runs fine when cold but after it gets warm it wont idle and i have to give it gas to start it. I checked the plugs and there is oil on them?
Old May 13, 2012 | 05:34 PM
Default Re: wont idle. trouble starting. oil in plugs?
Forgot to mention that this happened shortly after a couple of pulls to 8k rpm. My buddy thinks i fukd up the head.
The only code im throwing is for Secondary Oxygen Sensor Heater (HO2S) - P0141 (circuit malfunction)
They car runs fine untill it gets warmed up. Then it dies and wont idle.
Any ideas??
Old May 13, 2012 | 06:31 PM
minilogoguy18's Avatar
Oil in the tubes where the plug wires are or oil on the ends of the plugs inside the combustion chamber?
Old May 13, 2012 | 07:07 PM
Both. And there is quite a bit of oil
Old May 14, 2012 | 03:14 AM
Well that's incredibly simple then, go to the dealer and buy a valve cover gasket KIT, will come with the seals for the spark plug tubes, you should replace the plugs as well, possibly even the wires but you can test those first at least by checking their resistance.
Old May 14, 2012 | 07:04 AM
Ok thanks
But what is causing the car to die?
Old May 14, 2012 | 02:15 PM
Originally Posted by boost4life1
Ok thanks
Old May 14, 2012 | 05:09 PM
^Isn't it obvious? The plugs are ruined, the wires more than likely are too, had a 97 Odyssey today with the same problem, new seals and plugs, car runs fine.
Old May 15, 2012 | 07:15 PM
Replaced gaskets, plugs and wires. And it still will NOT idle.
Im pretty stumped right now. Any ideas?
Old May 15, 2012 | 08:52 PM
91DBrown's Avatar
Compression test?
alexahudson78
Jul 31, 2018 01:13 PM
nkmndz
Feb 25, 2012 05:12 AM
Egreyes
Oct 6, 2010 10:22 AM
.M.
May 22, 2005 03:08 AM
Innovative LS
Feb 4, 2005 12:41 AM
