Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Oil question?
Old May 12, 2012 | 09:01 AM
AC25's Avatar
Icon6 Oil question?
Hi all,
Which oil to use on a Honda Pilot 2005? With a 3.5L V6 engine (PFI SOHC 24V) 130,000 miles? My mechanic suggested 10W-20 because of the high miles. But the service manual suggested 5W-20. I also used full synthetic oil Mobil 1 old. Should I use 10W-20 only for the summer or all the time considering the high miles? Thank you guys for all you’re suggesting. Alex
Old May 13, 2012 | 08:57 AM
Honda_Enjineer's Avatar
Default Re: Oil question?
I have over 110K on my Pilot and I have no plans to switch to a thicker oil than the recommended 5W20 - I believe that it makes less sense these days and also when you have consistently used Mobil 1 fully synthetic oil in your engine.
My reasoning:
1. Fully synthetic oil does not break down like traditional engine oils used to so engine wear is noticeably lessened. 110K on a well cared for Honda engine is really nothing (I worry more about the tranny).
2. Honda engines are excellent - how often have you seen late model Honda's spouting blue smoke?
Switching to a heavier oil will probably only reduce your gas mileage and will not cause any damage. But I think you should focus instead on making frequent and regular oil/filter changes (and also increase the tranny fluid changes from the recommended rate - I do mine often).
Just my pennies.... but if you have 10 technicians you will get 10 varying opinions.
Old May 13, 2012 | 05:54 PM
AC25's Avatar
Thank you for your help. Yes I had the transmission oil change like 15,000 miles ago.
KFRG
Feb 8, 2010 05:56 AM
b20VTEC MONSTER
Jul 24, 2009 09:29 PM
Acura EL
Sep 20, 2004 07:38 AM
gary201147
Nov 30, 2003 12:34 AM
GruvyTune
Jul 24, 2002 09:58 AM
