ignition control module gone bad or else?
Old May 11, 2012 | 01:20 AM
celavi's Avatar
Default ignition control module gone bad or else?
I messed something up with my car, not sure what it is. When i pass 5k rpm the rpm tachometer goes crazy on me shivering between 5-8r[m, also if i go higher on rpm scale when i stop the car turns of, the ignition is also messed up it needs time to turn on. All of this happened while running some crome maps, and I also did some wiring to the car earlier that day. I think is ignition control module or coil in distributor, but not sure, if anyone has any other idea, please write it up, thanks.
Old May 11, 2012 | 06:21 AM
hardertuning's Avatar
Default Re: ignition control module gone bad or else?
http://youtu.be/H7aT3cmzvkU
At the end of this video theres some dash views and i think i had similar problems my tach bounced all over the place and my problem was damaged wire off the ICM that your talking about start there check all your work.
Old May 11, 2012 | 09:49 AM
celavi's Avatar
Thank you it was the wire off the ICM in the dizzy it somehow moved, i just had to turn it back. thanks.
si_motor_spt
Aug 16, 2007 05:12 AM
allblacksrt4
Nov 29, 2005 04:08 PM
Confuc1ous
Aug 23, 2003 11:17 PM
Jet Black
Jul 28, 2003 07:36 PM
keithv
Aug 20, 2001 01:10 PM
