where is the ignition control module
Old Nov 29, 2005 | 03:09 PM
allblacksrt4's Avatar
Default where is the ignition control module
i think my module is going out. my car is having a hard time starting after it has been sitting. once it start has trouble idling for a couple mins. then tach bounces after 4,000 rpm. i have a cel but haven't had time to check it. where on the motor is the ignition control module. also my idle to to high like at 1500 rpm.
Old Nov 29, 2005 | 04:06 PM
IN VTEC's Avatar
Default Re: where is the ignition control module (allblacksrt4)
It's inside of the distributor. It's the small rectangular inset piece with three spade terminals connected to it (it's next to the ignition coil). You'll be able to see it after you've removed the distributor cap, rotor, and the black plastic shield behind the rotor.
Old Nov 29, 2005 | 04:08 PM
95lstegman's Avatar
Default Re: where is the ignition control module (IN VTEC)
WOW! somebody actually needs one of these! i have one from my TD-55U '95 LS teg dizzy. i can even show you how to install it if you send me an email with some pics. my digi is temperamental(sp?) and isn't working right now.
angelito_h22
Jan 11, 2017 02:27 PM
celavi
May 11, 2012 09:49 AM
zrs6v4
Aug 4, 2009 06:29 PM
crxaddikt
Apr 14, 2003 08:25 PM
