Where is my brake fluid going?
Old May 10, 2012 | 12:35 PM
CBL9's Avatar
Default Where is my brake fluid going?
I have a 1998 Civic EX 2dr Auto without ABS, with rear drums. Has 170k on her.
2 years ago I did read brake lines, as I live up north and salt collected in that track and I had the puddle of fluid under the car etc.
I did rear lines with line from advance auto, and used the standard brass connectors in between sections. I used 2 60s on the driver side and 2 60s plus a 20 on the passenger side.
Over the past few months the level of fluid in the mc continues to drop, I refill, it brakes fine, then I keep adding every two weeks or so it is down 1/2 from he top fill mark.
Now I have checked for leaks... Rear drums, shoes, cylinders are 3 years old. No leaks. Traced the lines, and connectors (which is where I woulda bet my money... If I was a betting man) but no leaks. I did front pads and rotors since I noticed the fluid leaking, no leaks at the calipers or from the front lines. I don't see any fluid on the ground, just oil from the rear main seal.
What do I do? This is driving me crazy. How can fluid vanish from a closed system?!
Old May 10, 2012 | 12:37 PM
Dc4LsTeG's Avatar
EK9
Default Re: Where is my brake fluid going?
Is there fluid on the the brake booster under the master cylinder?
Old May 10, 2012 | 02:17 PM
CBL9's Avatar
I looked there too to see if there was an internal seal mc leak... Nothing is dripping down the firewall.
Old May 10, 2012 | 03:51 PM
MRGRIM's Avatar
R.I.P. Mark
they can also leak into the booster from the back of the master
and fill the booster full of fluid
canadaek's Avatar
remove the vacuum line and check in the booster i have found them half full of brake fluid before.
Old May 10, 2012 | 06:57 PM
CBL9's Avatar
Ok I will check that vaccum line.
So I drove the car tonight and the car pulled severely to the left when braking. Would this hint at a problem I am having?
Old May 10, 2012 | 07:13 PM
furious94ls's Avatar
It seems your problem lies with the right front caliper/lines. Check them closely.
Old May 10, 2012 | 07:22 PM
da1lydr1ver's Avatar
also check your right front caliper piston seal. my seal was completely torn recently from overheating the brakes and was leaking from around the caliper piston.
Old May 11, 2012 | 01:32 PM
CBL9's Avatar
I will pull that wheel tomorrow evening after work!
So when it pulls to one side the affected or damaged part is the opposite side? I guess that makes sense because all the braking force is coming from the left pulling the car to the left.
Interested to see what everything looks like in there.
nycpatron
Sep 6, 2016 06:58 AM
Tom_Tardivo
Dec 27, 2013 05:42 AM
D16SiHatch
11
Apr 28, 2011 08:00 PM
jdmboy96
Feb 10, 2009 08:44 PM
lif3tak3n
Apr 1, 2008 07:39 AM
