93' Honda Del Sol - rust, power window, and power steering questions!
Old May 8, 2012 | 06:28 PM
dontfrickk's Avatar
Default 93' Honda Del Sol - rust, power window, and power steering questions!
i just got a 1993 honda del sol.
few problems:
-right and back window wont work
-when it goes to start it almost seems like it struggles a little but starts right up
-engine has some rust
there are some normal problems that a 1993 would have.
i was just wondering what i should do about this and also what should i do to the car to make it look nice, ride nice, etc..
i was thinking about getting a full tune-up at a local shop to make sure everything is good.
let me know what anyone else thinks i should do...
also it doesnt have power steering can i get it? if so wheres at..
Old May 9, 2012 | 03:54 AM
92lxsleeper's Avatar
Default Re: 93' Honda Del Sol - rust, power window, and power steering questions!
it doesn't have power steering? please clarify
does it have factory manual rack and steering, or did the previous owner cut the lines and remove the pump?
Old May 9, 2012 | 06:19 AM
MySickSi's Avatar
Im.almost positive if you have the base model (s) they didnt come with power steering.
The window problem.i have no experience in, im sure a quick search on google will give you an answer.
Like you suggested, do a full tuneup.
Also where exactlynis there rust on the engine
Old May 9, 2012 | 03:48 PM
gzes's Avatar
probably window motor or swiches
Old May 9, 2012 | 07:36 PM
78F350's Avatar
I'm guessing that you are not very experienced as a mechanic.
Having a mechanic who KNOWs Hondas do a 'Pre-buy' inspection on it will teach you a lot. (Even though you already bought it.) $25-$45
Taking it in to 'Billy Bob's Lube and Repair' for a tune-up might get it running a little better, but could also get the wrong spark plugs etc. and miss some significant issues.
If it doesn't have power steering, you can get it installed, but these cars really don't need it. If it originally had it, the PS pump or belt was probably removed at some point to get a couple extra HP. Have a mechanic take a look, or post a picture of the driver's side engine compartment where the belt is on the engine.
Old May 9, 2012 | 09:06 PM
habanerored06si's Avatar
Exactly.
You're right side and rear window motor are going. Expect to replace.
Old May 9, 2012 | 10:46 PM
Dpsych's Avatar
the del sol has a window lock that turns off the passenger and rear windows i would make sure this isn't broken or switched on
nerD_alert
May 21, 2012 07:10 PM
Tazragoon
Oct 24, 2006 11:10 AM
goldenmac
24
Sep 16, 2006 01:11 PM
