LS Swap/Eg-ATF line routing?
Old May 8, 2012 | 11:26 AM
EGyoke's Avatar
Default LS Swap/Eg-ATF line routing?
I just picked up a EJ1 w/ an LS swap. I was looking through and inspecting all the lines and noticed that the ATF lines on the bottom of the radiator are just sitting there unplugged and hanging.....wonderful job guy!
Since the car does not have an Auto tranny (conv to a 5 spd w/ LS Swap),
Where should these lines go now?
I was wondering what others did?
There is no leaking from them but I just wanted to see what others did in this situation. Should I route them into each other and call it good?
Old May 8, 2012 | 11:36 AM
Dc4LsTeG's Avatar
EK9
Default Re: LS Swap/Eg-ATF line routing?
No leaking? What's the problem then? Just plug/block off them if they are leaking. Or if your worried about it go buy the right radiator, their cheap
Old May 8, 2012 | 11:37 AM
ehrkeith's Avatar
lol I mean they aren't going to leak anything if they aren't having fluid pumped into them. Cap them with some 2 dollar caps and call it a day if it really makes your engine bay look that bad.
Old May 8, 2012 | 12:15 PM
EGyoke's Avatar
No leaks. I just wanted to see if anyone else came up with a particular solution cosmetically so they look as OEM as possible. I could just cap them or route the lines into each other. If anyone has done anything else with their ATF lines on a 5 spd then let me know.
Thanks
Old May 8, 2012 | 12:30 PM
HondaPartsHero's Avatar
Technical Hero
Its probably an aftermarket radiator. Those are for the auto tranny cooler. Sometimes they come with caps but leaving them open won't hurt it either.
Old May 8, 2012 | 01:19 PM
grumblemarc's Avatar
The Grumpiest
Leave them be. It hurts nothing to leave them there.
Old May 8, 2012 | 02:01 PM
92lxsleeper's Avatar
your could always flush it out and turn it into an oil cooler somehow
Old May 8, 2012 | 02:45 PM
EGyoke's Avatar
Thanks bud. Thats what I was wondering. Ill cap em and call it.
sfgiants2k7
Jan 8, 2009 10:32 AM
e jay one
Dec 6, 2006 09:58 AM
Enternal
Jan 7, 2003 02:35 PM
