99 Ek wont start. Help plz
Old May 6, 2012 | 11:26 AM
SOLFOOD94's Avatar
Default 99 Ek wont start. Help plz
Drove the car fine this morning. Was cleaning up the engine bay for a few hours went to statr it and nothing happened. I can hear the fuel pump running and thestereo turns on. Jumped the starter solenoid to the large starter wire and it just turns over dont not start up. I hear a clicking when im turning over the key and thats it. Any help
Old May 6, 2012 | 11:41 AM
Dc4LsTeG's Avatar
EK9
Default Re: 99 Ek wont start. Help plz
Check for water in your spark plug holes and distributor
Old May 6, 2012 | 12:16 PM
SOLFOOD94's Avatar
Checked for that. None there
Old May 6, 2012 | 12:18 PM
Dc4LsTeG's Avatar
EK9
Are you sure theres none on the spark plugs? While cleaning did you remove or mess with anything? Check your engine grounds
Old May 6, 2012 | 01:01 PM
SOLFOOD94's Avatar
I just found out that the #31 fuse is getting no power to it. I cleaned the battery ground and reattached it thats it.
Old May 6, 2012 | 03:30 PM
slikz714's Avatar
Distributor?? Receiving any spark?? ignition module, ignition coil??
Could be the ignition rotor inside your distributor. if it is the ignition module, you should see a change of color (small circleish spot) behind/on the piece!
Old May 6, 2012 | 04:20 PM
Guateracer1's Avatar
Check the grounds too the one that is next to thermostat housing that one gives huge problems sometimes...
Old May 6, 2012 | 05:49 PM
SOLFOOD94's Avatar
I think i narrowed it down to the ecu being shorted. I checked the main relay all seems good but i have no pwer to the fuse # 31 not haviong power thus not letting the engine start due to power to the ecu. Picking up a ecu tomorow hopefully this works
1994turbocivic
Feb 10, 2011 06:26 PM
jonnybadboi9
Mar 14, 2007 06:17 PM
GQ Cowboy
Dec 14, 2003 09:55 PM
dsmith817
Nov 2, 2002 07:17 AM
HYBRIDGSiR
Nov 23, 2001 07:32 AM
