recomended oil presure on a turbo engine
Hello there. i am just curious...
how much is the recomended oil pressure on a turbo b16a2 engine?
mine oil presure gauge (glowshift) reads at
-800 rpm 18 psi
-900 rpm 22+ psi
-3000 rpm 60 psi
-4000 rpm until redline 80 psi
i see sometimes for 1-2 seconds at idle drops to 15 psi at 800 rpm after a lot of driving.
my oil pump is b16a2 OEM with spring from itr oil pump with 1.5mm washer too.
is this normal? my idle presure is low or is ok?
-800 rpm 18 psi
-900 rpm 22+ psi
-3000 rpm 60 psi
I have an h22 not a b series with an Autometer electrical gauge and that's basically what I'm getting..Your oil pressure shouldn't be any different with a boosted setup compared to stock.
That's a little low at idle compared to my car. I sit at 20-25 on mine. Every car is different though. My idle is also higher than 800 though..80psi is fine in the upper RPM range when I go past 4-5k its 75-80psi.
DISCLAIMER: I am not saying 9300 RPM is safe. But 80psi of oil pressure is fine for upper RPM IMO.
USDM 4G VTEC
Sep 3, 2003 08:26 PM
