99 accord idle problems
Old Apr 30, 2012 | 05:18 PM
joeski1982's Avatar
Default 99 accord idle problems
Hi i have a 99 accord f23a1 that i converted to manual i got a obd2b to obd1 conversion harness and a obd1 ecu socketed and chiped. I put 400cc injectors, t3t4 turbo, walboro 255, ssq blow off valve, and tial 38mm wastegate but it keeps going in limp mode no matter if i use the stock AT ecu or the obd1 and has surging idle with both ecu's. I've tried disconnecting the IACV with obd1 ecu and that didn't help. If anyone could help i would be http://images.ibsrv.net/ibsrv/res/sr...s/thud.gifmuch appreciative.
Old May 1, 2012 | 02:44 PM
Lost Again's Avatar
Default Re: 99 accord idle problems
Ok, I'll bite.....What codes are you getting?
Old May 10, 2012 | 12:43 AM
joeski1982's Avatar
with the stock ecu the only code I get is transmission malfunction. Is this enough to cause limp mode?
Truedeal
Engine Management and Tuning
Dec 4, 2017 07:09 AM
ZCHondaCRX91
Sep 11, 2017 01:23 PM
Turbo O
Aug 20, 2008 10:38 AM
kyden
Dec 3, 2004 09:00 AM
bbb18c1
Jan 12, 2003 01:40 PM
