Obd2 D15b/Y8 Timing Question
Old Apr 30, 2012 | 07:16 AM
Rclee91Ef's Avatar
Default Obd2 D15b/Y8 Timing Question
Looking for some information on a build im finishing up just need to pick out the timing belt that I need. I have a jdm obd2 d15b bottom end that i have rebuilt for a low boost application and put a usdm d16y8 head on its all together but ive been researching on the timing belt that I need. At first I was gonna just run it as the full d15b and i was gonna order the timing belt off the internet for that, but now that Im using the y8 head my question is being the d15b bottom end is basically a y series bottom end would having the y8 head to it be the same timing gear wise as a usdm y8 and use a ex timing belt or is the timing gear different. I dont have a y8 crank gear to compare it too and my searches through the d15b FAQ and other forums are all regarding either the obd1 d15b or z6 heads. Thank You
Old Apr 30, 2012 | 05:20 PM
Rclee91Ef's Avatar
Default Re: Obd2 D15b/Y8 Timing Question
I compared the crank gear to a z6 gear I had and it was the same in size and matched up tooth for tooth so looking at this as if it were a y8 head on a z6 swap would it be a y8 timing belt and good to go or a z6 timing belt and adjust the y8 cam gear 4.5 degrees
teggin97
Nov 24, 2009 06:33 AM
Bevenue
Mar 6, 2007 04:16 AM
THEDirtyDseriesWOOT
Sep 19, 2006 03:37 PM
blindoboy87
11
May 19, 2006 05:57 AM
mesmvc2
Apr 17, 2006 09:59 PM
