%%please for love of god help somebody $$$
I have a h22 turbocharged hatch running hondata and I just finished building the motor and was hoping to tune this Fri however I'm having major tps problems I just can't figure out when doing a little street tunning with my friend the car was bogging real hard in and out so I got out to check the connection on the tps and I unhooked it with the car running and got no check engine light with it disconnected weird so than I went home and hardwired it into the ecu today hoping that would just fix the problem reset it to 5v closed throttle 4.5 wot perfect so than I went ahead and disconnected it and no check engin light weird so any ideas would be a great help and yes the bulb is in the dash for check engine light ,,I'm all out of ideas so please anyone anything sorry for long post
did you reset the tps then do it in hondata
set closed and then held it open and set wot( in paramiters )
then upload it to the ecu
I'm gonna check that today in the hondata didn't do that first cause I don't really no how to use hondata...I got the motor and everything back together and I'm just trying to make sure everything is working before having it tuned,,, thanks for the help
dont worry about the voltage just do it in hondata look at there help page
http://www.hondata.com/help/smanager...parameters.htm
connect lap top
turn key to on with out engine running
connect button in hondata to ecu click it
select parameters tab
select TPS parameters
now click defaults
then with your foot of the pedal click minium reading
the with foot to the floor on the pedal click maxiuman reading
now on the menu bar you will see a big arrow button click it
this will upload the setting to your ecu
turn off key unplug laptop
now start car and see how it goes
if you got this all correct your tps is now set
connect lap top
now click defaults
Dude thanks ill give that a try when I get out of work,,,if for some reason that don't work do u have any other ideas I can try to stop it it from bogging sputtering at low rpms ??? I just can't wait to fix this problem so I can tune and drive it daily
Ok I figured that out my dam usb isn't connecting to the ecu I uploaded the s300 software a couple of times and nothin is poping up on the lap top, the usb jacks are working tried it with my wifes camera..I'm seriously lost now any help
Someone else on here is having issues with connecting to the s300. Try downloading the s300 software from Hondas website and installing sometimes that works.
Regardless though your tips needs to be at 0.5v closed and 4.5v open
I know this is a video on how to change TB, but it discusses about the voltmeter being used to determine actual voltage signal. If he's experiencing a bad TPS despite any Hondata calibrations, this old school physical way of determining things, will tell you if the TPS is perhaps bad, or if the wheel in the TB is not correctly operating.
http://www.youtube.com/watch?v=ukPoe5E4Fqg
Sweet thanks for the video,,I checked my tps wiring and my volt readings are Yellow wire 5.00 volts Red wire 0.50 volts and Green wire 0.03 volts ,,,,,,red and green look good but green is off its supposed to read 0.01 is this my problem possibly thanks everyone for the help
how's the throttle body itself? was it switched with another TB? Its narrowed down to these two items. TPS, TB, if software seems to be accounted for.
What engine harness are you running? What ecu? What locations did you hard wire the ecu in at?
You should have a 5v input a GROUND and an ouput voltage. I didn't see you mention checking your ground connection. Test for continuity from your ground wire at the tps to the thermostat. If you have a high resistance there it could be why your having problems.
After you give info on your setup I can check if you actuall have your tps wired in correctly.
Also are you opening your s300 under administrator?
myn takes 2-3 times its always been stuborn to connect
and make sure uyou have updated not just the s300 software but also the usb drivers are most inportant to update
keep trying they wil connect
I hardwired tps to to clip D red wire to pinD11-yellow wire to D20-green wire to D22 if i remember right I'm at work right now. Yellow wire is getting 5.00 volts red is set at 0.50 volts and green is at 0.03 which its suppose to be 0.01 could that be my problem ? I made all new grounds cleaned the spots up good also tried new tps sensor and stock ecu p30
