Oil Pressure...acting odd
Old Apr 29, 2012 | 10:12 AM
lostinmiself's Avatar
Default Oil Pressure...acting odd
So i have a ej1 with a b18b1/ls trans and a to4e turbo. Had 3in piping, some knockoff egay blow off valve and a front mount that has seen better days. I decided the 3in was in need of changing (ugly cutout bumper and blue) so i picked up some 2.5in egay special one kit fits all piping and a new front mount. Included was a HKS SSQV BOV to replace the egay one. So my journey began (car ran great) removed the 3 and installed the 2.5. Well now car is much peppier witch is fine needs a new tune i understand, but now my oil pressure spikes 80+ at maybe 1/4 throttle in 2-4 but in 5th its normal 40-60 rpm depending. Im trying to think of what could have made a difference. Or where this could have came from. Any help would be great.
-Lost
Old Apr 29, 2012 | 11:22 AM
Default Re: Oil Pressure...acting odd
Old Apr 29, 2012 | 11:25 AM
nealnanoHX's Avatar
Sounds fine to me. If it was low I would be concerned.
Old Apr 29, 2012 | 11:27 AM
from my readings dont you want the oil pressure around 70 at full throttle? if im mistaken then forgive me.
Old Apr 29, 2012 | 11:51 AM
98integralsB18's Avatar
they all differ a little bit. You what kind of gauge do you have do you have one with a sending unit, or a mechanical one. If mechanical you could have air in the line causing improper readings. If its a cheap gauge might be a little of and not be as responsive.
Old Apr 29, 2012 | 01:23 PM
viper_boy403's Avatar
Oil pressure is RPM dependent, it doesnt matter what the throttle position is. Check your wiring if its acting erratic
Old Apr 29, 2012 | 01:27 PM
Whiterice-gsr's Avatar
there is no issue here, like stated above dont worry until its low pressure.
Old Apr 29, 2012 | 03:29 PM
crvtectim's Avatar
I like to see about 10 psi oil pressure for every 1K rpms.
Old Apr 29, 2012 | 05:33 PM
blackeg's Avatar
yea pretty much, though at idle i think you should be in the 20's. there are variables here, including the fact that autometer electric oil pressure gauges suck.
at 3000 rpm my oil spikes up about 80 then comes back to around 70-75psi. its up toward 100 psi at my 9000 rpm redline. dont rely on the factory oil pressure light to let you know you have low pressure, that thing literally comes on at 3-5psi, at which point if your driving, your screwed
Old Apr 29, 2012 | 10:52 PM
turbohatch96y7's Avatar
whats a good oil pressure gauge to buy with a sending unit not mechanical?
Old Apr 30, 2012 | 12:46 AM
justYncredible's Avatar
It's wU to the sOLdiEr!
cant go wrong with autometer
i have an electrical oil pressure gauge
Old Apr 30, 2012 | 03:08 AM
blackeg's Avatar
No, you can go wrong with the autometer electrical gauge. The sending units are trash. I've been through 3 or 4 of them in the past few years in multiple cars. Sometimes they read funny other times they just stop working out of no where. Tired of replacing them all the time I sucked it up and bought the autometer mechanical gauge. Ill never have a bad sending unit again
Old Apr 30, 2012 | 03:13 AM
That's odd for you
I had one issue with mine the gauge was acting up. I emailed them and got a response the very next day. Gauge was repaired free of charge, try said some nut came lose and that was that. Non the less autometer is a good company overall
Old Apr 30, 2012 | 06:07 AM
nealnanoHX's Avatar
Autometer, Apexi and Defi and the best IMO.
Old Apr 30, 2012 | 06:04 PM
i will look into those this week, i have a equus gauge
http://yourautoworld.com/images/Jeep...-mechanica.jpg
never heard of them before but ill look into the AEM gauge as well
i think on friday i will get behind the dash and see what the previous owner did.
--on a side note what do you guys have done for a main power for the gauges? I really dont like the idea of 4-6 different power wires spliced into one. I was thinking of using a spair power block and seeing if some inline fused connections might clean up the wiring. thanks for all the imput so far
-Lost
Old May 1, 2012 | 01:42 PM
u can run them off whatever u want thats on with ignition i used a wire that i found floatin around not hooked up to anything that was hot with ignition. i have an autometer mechanical, imo mechanical is the way to go because if it is reading low u know there is definatley and oil problem at the very least a leak to the gauge.
Old May 5, 2012 | 03:42 PM
im going to start a build thread. thank everyone for the replies ill link to it if anyone is interested and cam continue there
josephcmiller2
Apr 29, 2011 06:40 AM
Samuels
Oct 28, 2007 08:36 PM
crxkid24
Aug 8, 2007 04:49 AM
turbotime
Jul 11, 2006 08:26 AM
pita106sg
Oct 31, 2002 05:26 PM
