Ball Joint (Upper)
Old Apr 29, 2012 | 08:31 AM
William1991b's Avatar
Default Ball Joint (Upper)
I know that the upper ball joint in together with the control arm. buy Can you just replace the ball joint? with out buying a new control arm.
Car: 1997 Accord Lx V6
Old Apr 29, 2012 | 12:29 PM
CD6fodoh's Avatar
Default Re: Ball Joint (Upper)
Yeah you can
Old May 3, 2012 | 06:15 AM
ctrain103's Avatar
yes u can just replace the balljoint. it is pressed in so u can have a shop depress the old one and press in the new one or you could just do it your self
Old May 3, 2012 | 12:13 PM
sgraham01's Avatar
if you replace the whole arm, you will also have new mount bushings and you can have it repaired in about 10 minutes. just don't spend the same on a ball joint and press labor as you would on a new arm, then keep old mount bushings. you have to take the whole arm off the car anyway to take it to a press unless you want to try pressing it with the arm on.
whyS0serious
Suspension & Brakes
Apr 17, 2018 12:45 PM
Big Jack Earl
Jul 6, 2009 10:01 PM
coojoe59
Jun 9, 2008 05:37 PM
digitalayon
Suspension & Brakes
Dec 19, 2005 05:26 PM
DaChoZn1
Jul 30, 2004 02:23 PM
