HOw to remove lug nut studs???trouble................
Old Oct 12, 2002 | 04:05 PM
VRD^don's Avatar
Default ohh. ****. broken wheel stud???trouble................
okay. i'm having trouble removing the old studs that hold the lug nuts. anyone know how to. need help badly.
[Modified by alpha_otto, 5:54 AM 10/14/2002]
Old Oct 12, 2002 | 05:40 PM
BreakStuff's Avatar
New User
Default Re: HOw to remove lug nut studs???trouble................ (alpha_otto)
Front or Rear?....
Old Oct 13, 2002 | 05:39 AM
JesseR's Avatar
If it's the front studs, then you have to have the hubs pressed out of the knuckle and have the studs removed....if you do that, spend the extra $70 from Honda and buy the wheel bearings and have those pressed in as well, that way you won't have to worry about bad bearings and have to take it all apart again.
Old Oct 14, 2002 | 04:52 AM
VRD^don's Avatar
Default Re: HOw to remove lug nut studs???trouble................ (BreakStuff)
the front and back.dicided to change all 16. cause one of them broke off in the front driver.
Old Oct 14, 2002 | 04:53 AM
VRD^don's Avatar
Default Re: HOw to remove lug nut studs???trouble................ (JesseR)
don't need new bearings. they still all good. just the wheel studs.
MadVladCivic
Dec 3, 2015 06:50 AM
peppers75
Honda CR-V & Element
15
Jun 25, 2011 09:31 AM
boun4door
Oct 1, 2008 03:32 PM
mingbling
Jul 27, 2004 09:05 PM
PA MATT
Aug 22, 2003 12:08 PM
