Extended Wheel Stud help
Old Jun 8, 2008 | 03:22 PM
boun4door's Avatar
Default Extended Wheel Stud help
how do you put Extended Wheel Stud on?
Old Jun 8, 2008 | 04:35 PM
old man neri's Avatar
Well you have to take the old one off which usually involves a hub removal. Unless you need them I would bother with extended studs.
Old Jun 12, 2008 | 12:05 PM
boun4door's Avatar
one of my Wheel Stud broke
Old Sep 29, 2008 | 08:53 AM
starbai's Avatar
Do you really need to take the hub off though?
I mean so long as you get enough room to put them in from the back, can't you just get some lug nuts to pull them through.
Old Sep 30, 2008 | 09:49 AM
luvtositdumpt's Avatar
From: somewhere in the d, mmm stake, mmm country fried stake
thats what is being said...there is not enough room to place them in from the back...hence him saying u might have to remove your hub...and getting them pressed...its already a pain to replace with factory studs
Old Sep 30, 2008 | 11:58 AM
crxd88's Avatar
Default Re: (luvtositdumpt)
Check out the new Honda Tuning they did a how to without having to press the bearings.
Old Sep 30, 2008 | 04:19 PM
hatchling37's Avatar
Default Re: (crxd88)
That ****'s a crock and they <U>do</U> state that you have to press the bearings. You're going to have to have them pressed out to remove and install new studs. Pain, yes. Be ready to replace your wheel bearing, too. I wouldn't reuse a bearing that's separated (they always come apart when you press the hub out of the bearing).
Old Oct 1, 2008 | 03:32 PM
Bigsouvy's Avatar
when i did it on my em2 and eg i hammer them in and welded the back of if.
ef90b16
Nov 28, 2008 09:36 PM
SomeGoodBud2
Suspension & Brakes
Mar 18, 2007 02:48 PM
dAng! Kris
May 3, 2005 03:51 AM
performula
Feb 19, 2003 03:08 PM
CRX7
Mar 17, 2002 01:44 PM
