Turbo Gsr very HIGH IDLE
I have an fresh fully built Gsr. Broke in motor first and was fine. after installing turbo on it, I can't even leave car on for an second, idle up to about 6000 rpm and climbing so I shut it off ASAP. Check all vacuum line, throttle cable, fpr and everything seem to be fine. I don't if I have to recalibrate the tps, but any suggestions will help. Thanks
What injectors are you running?? Stock??
Sounds like you have a huge vacuum leak possibly, or throttle stuck open. Only things that I can think of that'd make you rev to 6K without hitting the gas.
Sounds like throttle cable is to tight or incorrect throttle cable to short one or the other holding ther throttle plate open, would have to be a pretty big vacuum leak to bring the revs up to 6000rpm
he said he checked the throttle cable already
heres what im talking about
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-undo-adjustment-throttle-plate-stop-screw-2565744/
Thanks for all your opinion. Problem fix, was damn tps sensor. It wasn't tighten. Always gotta be the littlest things, lol. Now time to tune. Appointment set on may 9 at RLZ in north Carolina. Thanks again ht
