imobilizer removal??
Old Oct 12, 2002 | 10:36 AM
miahmouse's Avatar
Default imobilizer removal??
Anyone know how to remove/disable/bypass the immobilizer function in a 00 gsr? I'm currently running my b18c1 swap on a 99 si ecu but would like to be running the gsr ecu. I know it can be done (www.locashracing.com has done it), just seeing if anyone has done it themselves.....
Old Oct 12, 2002 | 06:13 PM
BreakStuff's Avatar
New User
Default Re: imobilizer removal?? (miahmouse)
If I understand correctly... If you are going to be re-installing the original ECU, then the immobi system should function normally and not prevent you from starting the car..
Old Oct 14, 2002 | 10:41 AM
miahmouse's Avatar
Default Re: imobilizer removal?? (BreakStuff)
this is on a swap, a 00 gsr into a 99 ex. I have neither the transponder key or the part that reads the key.
edit:
also.....anyone have the pinout diagram for the 00/01 gsr ecu
[Modified by miahmouse, 7:45 PM 10/14/2002]
JdmCrx209
Jan 18, 2013 09:57 AM
415Hatch
Aug 29, 2010 08:28 AM
beeswapping
Aug 12, 2010 09:04 AM
slomofo
Jul 8, 2005 04:56 PM
