b20b w/ ls tranny turbo build.....what all shud i switch?
Old Apr 23, 2012 | 04:18 PM
cody_sandlin's Avatar
Default b20b w/ ls tranny turbo build.....what all shud i switch?
Im planing on putting a turbo on a b20b w/ ls tranny and was wondering what all i shud switch out im only doing about 5 lbs of boost.
Old Apr 23, 2012 | 05:00 PM
Turbo-LS's Avatar
Default Re: b20b w/ ls tranny turbo build.....what all shud i switch?
What do you mean switch out?
Old Apr 23, 2012 | 05:22 PM
like what type of intake manifold or like rods or rockers ecu
Old Apr 23, 2012 | 05:24 PM
Turbo-LS's Avatar
Read the facts will give you everything you need to now
Old Apr 23, 2012 | 05:32 PM
its a b20b and im getting a transmission outta a 92-93 ls integra. im gonna swap out the engine in my 91 crx and put that in it.
Old Apr 23, 2012 | 06:00 PM
jfoster's Avatar
Cool story bro.
Lets start with your turbo set up. What parts are you planning to use?
Old Apr 23, 2012 | 08:22 PM
dantamparacer's Avatar
Be specific with your goals, 5psi means nothing to anyone here except you. 5psi on my 16g is not the same as 5psi on a 42r. Let me help you out here, answer these questions.
What is the purpose of the car ( daily, drag only, what)?
What is your goal (hp, 1/4 mile, ect)?
What parts do you already have(fuel system, turbo, engine parts, ect)?
What is your budget? (don't give us a B.S. answer like there isn't one)
Old Apr 24, 2012 | 03:23 AM
EsotericImage's Avatar
Retired Moderator
Old Apr 24, 2012 | 03:47 AM
yungkhmer's Avatar
THIS.
Old Apr 24, 2012 | 06:13 AM
Its gonna be my daily driver. I just wanna gain some hp torque and mpgs. I currently have a stock b20b from hmotors and a ls tranny. I was gonna buy little pieces over time till i have everything then id take everything apart and switch it out
Old Apr 24, 2012 | 06:34 AM
Ok now you are getting close but you still aren't smart enough to figure this out. KEEP IN MIND you are posting this in a forced induction forum. I get you want it to be a daily driver and buy a piece at a time until you have everything you need. Now you say you want to make more power, torque and mpg. Do you want a 250whp dd or a 500whp dd? What fuel? Do you want to supercharge it our turbo it our even just put a nitrous kit on it? All of these are questions you need to answer for us to help you. You version of a dd may not be the same as mine. I can give you a list of parts that will work but it might not meet YOUR goals
Old Apr 24, 2012 | 06:40 AM
I want like a dd with 250whp on normal gas. Just a turbo kit no nitro or supercharger.
Old Apr 24, 2012 | 01:54 PM
Retired Moderator
Thats exactly what I wanted/have. Not too powerful, but can still get down when needed
https://honda-tech.com/garage/1999-H...ericImage.html
Old Apr 24, 2012 | 03:44 PM
ok cool thanx but was it reliable? i dont want it to be in the shop or broke down all the time. is there any problems that occur alot in ur car?
Old Apr 24, 2012 | 03:50 PM
yungkhmer's Avatar
just go buy a full ebay turbo kit and all it a day. theyre cheap.
Old Apr 24, 2012 | 05:58 PM
idk i want it reliable tho. like i said i dont want it in the shop all the time
Old Apr 24, 2012 | 08:43 PM
jfoster's Avatar
The reliability is a direct result of the quality of the parts used, and the competence of the installer/tuner. That said, all modifications that increase power substantially have some decreasing effect on the lifespan of an engine. Increased horsepower means increased stress on parts.
Approximately how much money are you looking to sink into this car?
Old Apr 25, 2012 | 06:01 AM
I dont wanna sink like a crazy amount but prob 2 or 3k at most.
Old Apr 25, 2012 | 04:10 PM
*bump*
Old Apr 25, 2012 | 08:12 PM
Retired Moderator
All is true except the bold area.. If tuned correctly, the engine should last as long as any stock engine.. as long as it isnt being revved to the moon and abused.. Just like any other engine on the planet.
If you want reliability then you cant be cheap. When you increase the power by 150% expect to have some issues as you will find the weakest link. Clutch, axles, mounts should be replaced when going boost.
Fast
Reliable
Cheap
Pick 2 and the 3rd is what its not.
Research your tuner and make sure hes not a flake with a laptop
Old Apr 26, 2012 | 07:09 AM
Ohh ok. I thought it wud be like broke alot. As long as it tuner properly it ahud be like a normal engine. Like how a turbo diesel dont break.
Old Apr 30, 2012 | 12:58 PM
jfoster's Avatar
Fast
Reliable
Cheap
Regardless of tuning (assume its excellent tuning if you wish) if you take two of the same motors and double the horse power of one of them, it its under more stress. The bearings, rods, pistons, rings, head gasket, head studs,cyl walls, etc are all enduring a more powerful combustion.
OP- you never listed what your turbo set up consists of, or are you planning to buy a specific "kit"?
Well, more like how any other turbo car can be reliable (lancer,sti,etc) not really like a Cummins diesel at all. I don't know of any 500k+ mile turbo Hondas.
Old Apr 30, 2012 | 06:01 PM
i was thinking bout getting a garrett turbo kit. they seem to be reliable and popular
Old May 1, 2012 | 06:26 PM
bump
Old May 1, 2012 | 07:56 PM
MR.johnson's Avatar
they dont make turbo kits for hondas.
