99 Turbo civic steering problem?
Old Apr 23, 2012 | 10:55 AM
MonKK's Avatar
Default 99 Turbo civic steering problem?
Just bought a 99 si turbo.........whenever i give it some gas the car will swerve to the right and very hard to control....i dont know why..........alignment is still good, car doesnt swerve or nothing while cruising......car have no power steering fluid.........Has skunk2 lower control arms....maybe previous owner didnt install the control arms right? Also have skunk2 coilovers and is dropped pretty low......think is should raise it back up and get alignment? ANY HELP OUT THERE!....THANKS ALOT
Old Apr 23, 2012 | 10:59 AM
kyden's Avatar
Default Re: 99 Turbo civic steering problem?
it's called torque steer. get used to it with an open diff.
Old Apr 23, 2012 | 11:07 AM
MonKK's Avatar
even when accelerating slowly it will swerve hardcore back and forth
Old Apr 23, 2012 | 11:12 AM
ehrkeith's Avatar
Can't see under your car so I suggest you jack it up and check for play in your tie rods, ball joints, upper and lower bushings. It also sounds like some torque steer but it can probably be drastically worse with bad steering/suspension components. If it looks worn replace it. Almost every steering/suspension component in the front end can be replaced with new stuff for around 200. It just takes awhile.
Old Apr 23, 2012 | 11:47 AM
danielcamargo's Avatar
If the steering problem is bad enough to ask about it then its probably a shot rack and pinion , inner tie rods.
When I had that problem I would accelerate and have to compensate the torque steer then when I went to brake I had to real compensate it going the other way.
Lift the car up and check out your inner tie rods, check for play.
Old Apr 23, 2012 | 01:28 PM
MonKK's Avatar
Thanks everyone imma check first thing after work
Old Apr 23, 2012 | 01:55 PM
BryanM.'s Avatar
Resident Gearhead
Not good. Look into fixing that.
Most likely.
Old Apr 23, 2012 | 02:03 PM
jbpnoman's Avatar
I would usually agree with torque steer, but he's saying it's pulling "back and fourth". Torque steer doesn't do that. OP, there's something wrong in your steering. Check EVERYTHING for play.
96hb
Suspension & Brakes
40
Feb 5, 2013 12:16 AM
Drop_A_Dookie
12
Feb 13, 2011 07:56 PM
quick_ls
Jan 9, 2008 05:54 AM
Yellowone
Apr 6, 2006 05:30 PM
LSV_REX
Mar 31, 2006 12:36 PM
