2000 Civic Si tweeter doesn't work - replace with OEM or aftermarket?
Old Apr 22, 2012 | 07:41 PM
Bertsch911's Avatar
Default 2000 Civic Si tweeter doesn't work - replace with OEM or aftermarket?
yeah in my 2000 civic si my driver side tweeter doesnt work. should i replace it with stock or could after maker ones fit in their. and if so how do u wire them up. thanks
Old Apr 23, 2012 | 06:05 AM
motegicivic's Avatar
Default Re: 2000 Civic Si tweeter doesn't work - replace with OEM or aftermarket?
The tweeter hooks up parallel to the door speaker. basically half down there is a connector for it.
You 2 options replace with stock take off door panel and unclip stock one.
or aftermarket one typically they have a cross over, might as well replace the door speaker as well hook both off the cross over and done, use the speaker wires in the lower part of the door by the 6.5 woofer you can get a harness to plug in to it and will give you a positive and negative wire. As for the tweeter get one .75 inches to fit the best, you might have to open the tweeter pod hole a but and just glue it in.
Old Apr 23, 2012 | 07:12 AM
Jimster480's Avatar
You could replace it with a stock one, they sound fine. I never had them until recently when I got another EX and the ones in that car work.
young geezer
Jan 21, 2011 03:26 AM
cooljnateman
Audio / Security / Video
Mar 15, 2010 08:56 PM
tuhboek
Feb 11, 2010 02:44 PM
Chief0424
Apr 4, 2005 11:24 PM
turbospool
Mar 10, 2003 09:06 PM
