2000 Si door fit?
2000 Si door fit?
I have a 96 civic hatch DX. I need a passenger door for it and I came across a 2000 civic Si door. My question is will the door fit correctly I believe it will but I just want someone to confirm this. Also the Si is obviously power window and lock...so If I used the Si door how hard is it to convert the door to manual lock/window if it is possible?
Thanks
Thanks
Re: 2000 Si door fit?
Well it looks like you are IN LUCK IF YOU HAVE A 3 DOOR DX. I looked up the Honda OEM part#s for a 1996 3dr DX, and a 2000 Si THE PART#S ARE THE SAME
BUT IF YOU HAVE A 4 DOOR DX THE DOORS ARE SHORTER and you are SOL.
http://repo.jackmoves.com/v/erik/album106/album206/
i believe you'll need a ex harness i havent done this myself yet.. i plan to
H-T White Ops
The body of the door itself is the same for all '96-'00 Civic coupes and hatches. Sedan doors are shorter.
The wiring is where you can run into problems since the harnesses changed in 1999.
pcconway
09-21-2016 04:48 AM
Skip01
11
02-27-2014 09:11 AM
young geezer
01-21-2011 03:26 AM
