Del sol clutch problem
Old Apr 22, 2012 | 09:52 AM
509delsol's Avatar
Default Del sol clutch problem
I replaced the clutch on my sol because i thought it was slipping. So I replace my clutch on my d15 del sol and resurfaced the fly wheel and all that . So I have had it on my car on my car for a month and in order for the clutch to engage I needed to take the clutch almost all the way out and when I'm on the highway for a while and downshift to go up a hill it seems to slip and just rev up and I have to let go of the gas so it can engage again . Help on what it could be :/
Old Apr 22, 2012 | 11:41 AM
509delsol's Avatar
Default Re: Del sol clutch problem
Bump . Could it be the clutch master cylinder ?
Old Apr 22, 2012 | 12:24 PM
nealnanoHX's Avatar
Yes it could be. What clutch are you using?
Old Apr 22, 2012 | 12:52 PM
94EG8's Avatar
Seagull Management
No it couldn't. Nor could it be the slave cylinder. They only release/disengage the clutch.
If it's slipping it's worn past the service limit, or it's contaminated with oil/grease/transmission fluid etc. I don't suppose you have picture of the clutch you replaced?
Old Apr 22, 2012 | 01:27 PM
509delsol's Avatar
I don't know we're it's at at the moment but it still had life and don't see why it would slip.
Well when I replaced it I made sure everything was clean and put the cover back on the transmission . Unless my tranny is going out ?
Old Apr 22, 2012 | 01:35 PM
grumblemarc's Avatar
The Grumpiest
Now we're jumping to the transmission? If the clutch is slipping then it's the clutch. That is, unless you don't actually know what a slipping clutch actually feels like. I say this because you say it "seems" to slip. Trust me. If your clutch was actually slipping, you'd know it.
Old Apr 22, 2012 | 01:38 PM
509delsol's Avatar
Well the clutch is maybe 1000 miles in so I don't see why it would be slipping
Old Apr 22, 2012 | 01:44 PM
The Grumpiest
There would only be two reasons. Both of them listed in post #4. If you didn't break the clutch in properly you probably glazed it all to hell. Either way you have to pull the transmission to inspect.
Old Apr 22, 2012 | 01:53 PM
Hidenplanvew's Avatar
what brand clutch did you replace your worn out one with?
Old Apr 22, 2012 | 01:54 PM
509delsol's Avatar
I'll pull it off this week and I'll upload some pictures
drlagares
18
May 30, 2015 03:46 PM
yunebug
Jun 15, 2010 07:29 AM
shady3260
Transmission & Drivetrain
Dec 19, 2009 10:27 PM
94SolMan
Apr 29, 2009 12:07 PM
yaba3800
Sep 14, 2008 02:57 PM
