Honda B Series 4 Wires O2 Sensor
Old Apr 22, 2012 | 09:36 AM
9tailsfox's Avatar
Icon6 Honda B Series 4 Wires O2 Sensor
Hello, Is been sick of my CEL Flash. I get the code is O2 Sensor #1. So I just replaced working fine used sensor from my friend's car. But still get the CEL flash. So I try to find the causes one by one. There will be two possibilities which is the O2 sensor or the harness wire need to replace. So 1st, how do I test the O2 sensor through the 4 wires by using multimeter? and how I determine the harness wire problem? Thank You
Old Apr 22, 2012 | 09:49 AM
MMMGIRL's Avatar
Default Re: Honda B Series 4 Wires O2 Sensor
Did you reset the ecu after you swapped them?
Old Apr 22, 2012 | 10:02 AM
9tailsfox's Avatar
Yes, I did unplug the negative battery to reset ECU. But no luck still flash the CEL code O2 sensor #1 after a few miles driving. So how to back probe ans test by using multimeter? Thank You
Old Apr 22, 2012 | 10:28 AM
Former User's Avatar
You MUST provide all pertinent information about your car and engine. Failure to do so may result in thread closure.
Old Apr 22, 2012 | 07:24 PM
9tailsfox's Avatar
I'm sorry, My engine is B-series b16b, the harness I'm using is the B16a obd1. Everything work perfectly before I change my JDM ITR 4-2-1 to JDM ITR 4-1 header. Could it be the cable harness problem?
bobcollege
15
Mar 22, 2018 10:12 PM
phbrush
27
Dec 17, 2014 07:25 AM
EX-T
Apr 24, 2006 02:55 PM
projectEK9
Honda Motorcycles
Jun 9, 2005 10:45 AM
Cutlass355
Apr 30, 2005 03:31 PM
