Please analyze my flywheel and clutch! (warning: BIG pictures)
Hi everyone. Well, i've already sent my clutch disc off to clutchmasters to get new materials installed, but can you guys just take a look at the other bits and pieces for me, and help me analyze whether I should have sent anything else off to get fixed up?
I felt that there was no need to send the flywheel and pressure plate because they looked okay, and my mechanic said they're still usable. Also, can someone PLEASE tell me what flywheel i'm using? I don't know if it came with the clutch or not, as it was already in the car when I bought it. I do know that i'm using a stage 4 CM clutch. Your help is appreciated, as always
thanks.
I also gathered you guys would want detailed pictures, so here they are - big. If you're on a modem, and they all don't load up properly, just click on refresh
thanks.I also gathered you guys would want detailed pictures, so here they are - big. If you're on a modem, and they all don't load up properly, just click on refresh
Personally i would have got the flywheel surfaced, it looks to have hot spots on it.
But i get it resurfaced everytime i do a clutch, meticulous i guess.
Rob
Rob
OK, well I'm sure I can get the flywheel resurfaced here, that's no problem.
Does the pressure plate look okay?
Does anyone know what brand my flywheel is, and perhaps, what model it is? I really really want to know
ok, so its a CM/Fidanza flywheel.. the previous owner probably got it with his stage 4 clutch..
does anyone know the weight of the flywheels that come with the CM stage 4 clutches?
That would be 3.4kg i believe. Also, what are some goods shops for turbo parts around Bangkok? I want to bring some things back next time I go.
Nick
