Transmission & Drivetrain Gearboxes, Differentials, Clutches
main shaft help
Old Apr 20, 2012 | 06:49 AM
jaw0885's Avatar
Default main shaft help
Looking for help on which main shaft to use. They are both type r but i noticed one has a bigger oil passage than the other. Any help would be appreciated. Thanks
Old Apr 20, 2012 | 08:17 AM
David @ Synchrotech's Avatar
Default Re: main shaft help
Use the one with the oil guide insert (smaller oil passage). The other ITR mainshaft with the insert removed shoud not be reused. The plastic oil guide plate in the top case feeds into this passage and will not have proper lubrication without the insert.
Old Apr 20, 2012 | 09:13 AM
jaw0885's Avatar
I figured that would be the answer. thanks for the quick response and the deal on the rebuild kit i just got from you
kutlee
Apr 18, 2015 04:52 AM
blackeg
Aug 10, 2006 09:13 AM
93hatchin
Jul 25, 2005 04:49 AM
Si_LuDer
Aug 16, 2002 08:21 PM
