2001 honda civic d17a2 problems
so i have a 2001 honda civic turbo. on a completely stock motor i made 230 whp on 9 lbs.. recently i purchased a crower stage 2 turbo cam and took it to the machine shop and had it installed. the cam was set a tdc with an adjustable cam gear. the problem i had was when i went to the dyno my hp went down to 130 on 7 lbs.. at first the assumption was because the cam was not degreed in but after talking to many people everyone is saying you will not lose that much power off that alone. i have also heard that possibly the rocker assembly was not assembled properly. can anyone help with what the problem may be. thank you so much
dravesef
15
Jan 21, 2008 09:25 PM
