OBD1 92-95 jdm b16a swap into OBD2 2000 si - Will it run?
Old Apr 19, 2012 | 07:24 PM
k-seriesem1's Avatar
Default OBD1 92-95 jdm b16a swap into OBD2 2000 si - Will it run?
I just bought a 2000 si w/ a jdm 88-91 b16 (obd0) but its running the stock 2000 si ob2 wiring harness and it ran till I drove it in the rain and my aem cai sucked up water and the engine cracked 2 rods in half. Im buying another 92-95 jdm b16a which is obd1 BUT i have the stock obd2 wiring harness. My question is, If i bolt up the engine and plug everything up, Will it run ?
Old Apr 19, 2012 | 08:38 PM
beecee18's Avatar
Default Re: OBD1 92-95 jdm b16a swap into OBD2 2000 si - Will it run?
hydrolocked, lolz, check out my build thread same car,
bought it with the same engine failure
Old Apr 19, 2012 | 08:43 PM
beecee18's Avatar
And to answer your question
I would assume before the hydrolock inccident that all was well, motor made decent power, no faults (CEL) ect.
You would simply replace the long block assy. and use the sensor/wiring setup that was being used with that older motor.
On the good side you have a little more pinch of power out of that sir2 motor for sure compared to the old salty B16.
And the butt dyno will notice.
Old Apr 19, 2012 | 10:05 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Yes. The OBD1 engine will bolt in. Your harness will plug into it. It will run. Re-use your OBD2 distributor.
Old Apr 20, 2012 | 02:49 AM
rice a roni's Avatar
it should bolt right up. going obd0 to obd1 doesn't require any extra sensors.
Posted from honda-tech forums Reader for Android
Old Apr 20, 2012 | 11:06 AM
Im was running the stock 99-00 Si obd2 ecu with my obd0 b16 that got hydro locked and it ran. I'm assuming the 92-95 sir2 motor will run as well? Thanks alot guys
Old Apr 20, 2012 | 04:46 PM
B serious's Avatar
Yes.
Old Apr 20, 2012 | 09:24 PM
4drferio's Avatar
should of convert everything into obd2b
Old Apr 23, 2012 | 05:52 PM
So I have to use my obd2 distributor correct, thanks so much guys!
Old Apr 23, 2012 | 06:41 PM
beecee18's Avatar
Old Apr 23, 2012 | 07:09 PM
KINGVEM^^ED6's Avatar
Pull out old motor
Bolt intake mani exhaust mani and dizzy on to new motor
It will run fine
Old Apr 23, 2012 | 07:34 PM
egsleepercivic's Avatar
use the obd2 injectors as well the clips are a little different iirc
Old Apr 24, 2012 | 06:49 AM
****, how can I identify my injectors? I have no idea if the people who owned the car before me used obd0 injectors or if they used the stock obd2 injectors
Old Apr 24, 2012 | 06:52 AM
Kingvem, I'm guessing that's all the obd2 stuff I need the car necessary to run? What a headache
Old Apr 24, 2012 | 02:09 PM
What do I do about the crank sensor on the obd2 wiring harness?
Old Apr 28, 2012 | 01:25 AM
well i just figured out that the 92-95 jdm b16a doesnt use a cranks sensor so i had to put my b16a2 crank sensor in the block, im guessing i have to swap my b16a2 manifold as well cause the 92-95 model has an extra sensors on the throttle body and also on the intake manifold, all this so i can run my obd2 wiring harness. has anyone swapped a 92-95 b16a into a em1? if so, what changes did you have to make? (without converting to obd1)
NOman0608
May 12, 2007 08:39 PM
whiteb16a
Oct 20, 2004 11:34 AM
Red_EM1
Jun 9, 2004 07:20 PM
ScottEK
Jan 29, 2004 05:55 AM
ScottEK
Jan 24, 2004 11:09 PM
