Disgusting Grinding Noise... Please advise...
Old Apr 19, 2012 | 05:42 PM
mah_doode!'s Avatar
Icon2 Disgusting Grinding Noise... Please advise...
Hello all,
I have a 1998 Honda Civic M/T 1.6L non vtech SOHC. and I have been having this issue for about a month now. At first I thought it was the brake pads, a lil bleed on all four corners. So i did this and i kept having issues. SO then i changed out the master cylinder, and bled all four corners and still this nasty grinding sound. I then thought that it was the caliper seizing up, so i recently changed the caliper and pads AGAIN, and i bled all four corners again. I drove the car today and on my way to work i started to hear that same sound. I took a video, but if it loaded... Does anyone have some insight on what the issue might be?? Please advise I would greatly appreciate any info on fixing this.
this is really frustrating not to mention im having to bleed and replace pads constantly
http://s1244.photobucket.com/albums/...current=73.mp4
MUCH THANKS!!!!
Old Apr 19, 2012 | 05:45 PM
vitamin_c95's Avatar
Default Re: Disgusting Grinding Noise... Please advise...
link no worky
Old Apr 19, 2012 | 05:49 PM
mah_doode!'s Avatar
yea im tryna wokr on this sorry
mah_doode!'s Avatar
im working on getting a working link
Old Apr 19, 2012 | 05:59 PM
TheJGB3's Avatar
Probably bad front tires (what it was on my 2000 EX), or a bad wheel bearing.
I had an awful grinding noise on my '00 EX when I bought it. It had sh*tty Walmart Goodyear tires on it. I replaced the tires and the noise is gone.
Old Apr 19, 2012 | 06:01 PM
mah_doode!'s Avatar
i think the link works now
Old Apr 19, 2012 | 06:03 PM
mah_doode!'s Avatar
The tires have been good i had changed them not too long ago, but I was thinking about replacing the whole hub tomorrow. I don't wanna spend money on parts that probably wont fix the issue
Old Apr 19, 2012 | 06:28 PM
MRGRIM's Avatar
R.I.P. Mark
I would jack it up and check the wheel bearing when its hot after a run
and also check the disc dust sheild as it might warp when hot
if you have abs check the abs ring on the drive shaft
that sound is deff metal on metal !!
nothing to do with tires
Old Apr 19, 2012 | 06:35 PM
mah_doode!'s Avatar
Awesome!!!! I just needed a few confirmations prior to replacing parts, its frustrating and annoying not knowing how to fix this issue.
Old Apr 19, 2012 | 06:42 PM
mah_doode!'s Avatar
The disc dust shields had already kind of bent out of shape since when i first bought the car for my gf it had 18 inch rims. (already have stocks on it).
Old Apr 19, 2012 | 06:56 PM
Bradshaw's Avatar
to check wheel bearings jack up car till the tire is off the ground. grab it at 12 and 6 oclock positions and see if there is any play. if there is, wheels bearing is out.
even if there isn't play, it may still be going out just not enough play in it to feel it.
Old Apr 19, 2012 | 09:11 PM
beecee18's Avatar
you would be surprised by what funky stuff bad tires does to cars in some instances just sayin.
Old Apr 20, 2012 | 01:12 AM
jbpnoman's Avatar
You have that backwards. 12/6 play is ball joints. 3/9 play is bearings.
Old Apr 20, 2012 | 08:05 AM
94EG8's Avatar
Seagull Management
It doesn't really matter where you grab it to check for a bad wheel bearing, it'll have play in any direction. Ball joints you can't really check that way unless they're about ready to fall apart. use a large bar with the weight still on the joint.
That doesn't really sound like a bad wheel bearing though. It sounds horrible, just not like a wheel bearing.
Old Apr 22, 2012 | 12:44 PM
mah_doode!'s Avatar
***Update***
Got a hub from the junkyard. Once I took the old hub off I was able to verify that there was play in the wheel bearing. Changed the hub, the easiest thing to do. Used 17mm on all 5 nuts, caliper bolts included, however I did have to pick up a 32mm axle nut socket. Put everything back together, Problem is gone.
Thanks all!
canooten
11
Sep 12, 2014 09:39 AM
SoftBank
May 12, 2014 07:50 AM
donut_eh3
Suspension & Brakes
Mar 30, 2011 01:03 PM
StreetRacin101
14
Apr 2, 2009 11:14 AM
paxorion
Aug 4, 2006 06:30 PM
