Turbo oil feed : Homemade gasket? Banjo bolt oil flow?
The gasket I received leaked really easily and ripped. Can I make my own out of a soda box like I did with the return and my bov?
Also, I have a journal bearing turbo. I want to run a banjo bolt straight into the feed (I wont need the gasket)
I know journal bearing turbos should not use a restrictor. Should the banjo bolt flow oil through my turbo at a safe rate? I'm sick of these ****ing leaks with the flange and gaskets I have/had.
I have a precision 4431e t3 .48 ar 60 cold stage 3 wheel
Thanks
Thanks
tightened the bolt more lol.. stopped the leak, ****. how do I check n see if my return line is flowing correctly? or do I just gotta make damn i'm its flowing well?
BlueShadow
Jun 23, 2005 06:14 PM
