Distributor
My friends 95 Teg, needs a new distributor, you hear the notorious noise.
He called the dealer and they wanted $500.
What other options does he have? Are there any good aftermarket brands?
I've heard to generally stay away from non OEM Ignition products.
Should he go to a junk yard?
Thanks
Thanks
because of your location i would ask the local jdm importers. the oem distributors are getting harder and harder to find in good condition and often sell used for $150-200. these are first choice if you can find one
moroso now makes a vtec distributor which is one thought since it's finally a quality brand. also affordable at $150 on ebay
go to acura oem parts and buy just the distributor housing.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
90+ shipping and transfer over icm/coil and whatever else is needed. he's lucky he doesnt have a obdII housing because those cost a lot and there is no difference except wiring.
if his icm/coil are old, he should consider changing those too.
I have an OEM OBD-1 VTEC distributor for sale....TD-44U. I dunno if that would work on his motor as well. I only want $100. Has a brand new ignitor, coil, and ICM inside as well.
my friend is a using an OEM 95 integra dizzy housing in his 2000 integra. I'm not sure whats involved in the conversion whether it be simply moving the wires over and/or soldering. The only difference is the plug. he has 50k on his conversion and his car drives perfect.
haha 334 for the obdII housing
ubreak_ubuy
Jul 27, 2004 04:48 PM
