lsvtec sluggish. no power. timing question
Old Apr 19, 2012 | 07:36 AM
dustinbs144's Avatar
Default lsvtec sluggish. no power. timing question
my lsvtec is extremely slow. it feels like it has absolutely no power above 3000 rpms. i think it has to do with my cam and ignition timing. i never bothered to adjust either of them. right now the car has a p28 with a pretty decent basemap on it. i dont have enough money to get it tuned as of now.the motor is a b18b block manley rods manley pistons 9:1 cr b16a2 head itr manifold and tb header and exhaust. could it be just the low compression that is making it sluggish or could the timing be doing it? what should i adjust the cams and ignition to? thanks
Old Apr 19, 2012 | 10:35 AM
Odin Nielsen's Avatar
Default Re: lsvtec sluggish. no power. timing question
Was it always like this or did it just start suddenly?
Old Apr 19, 2012 | 11:31 AM
sleepencivic's Avatar
dont drive the car if the cam timing is not set you will damage your motor!
Get a service manual from advanced auto and start reading! For the cam timing align all three marks 2 on the cam gears and one on the crank, set the ignition timing for 16.5
Old Apr 19, 2012 | 05:30 PM
the belt is lined up properly. i have adjustable cam gears i set them at 0. ill do the ignition timing tomorrow morning... since my car is now using a p28 with a jumper how do i go about timing it. btw is a 2000 em1.
kirkland08
Feb 13, 2011 08:59 AM
KeithsDAteg
Nov 29, 2009 05:32 PM
NorthernXposure
Oct 13, 2006 07:24 PM
donnjuan2point2
Mar 11, 2004 10:49 AM
redcxhatch
Nov 16, 2002 08:04 AM
