Hondata intake gasket with high boost?
Old Oct 11, 2002 | 09:41 PM
earl's Avatar
Default Hondata intake gasket with high boost?
Has anyone used the Hondata heat shield intake gasket with boost of 30 lbs? Since it's made of such a hard material, I'm wondering if it can hold that much pressure. We have one to try but just not sure of it sealing ability.
Old Oct 11, 2002 | 09:56 PM
Hondata's Avatar
Default Re: Hondata intake gasket with high boost? (earl)
no problem
Old Oct 11, 2002 | 10:17 PM
earl's Avatar
Default Re: Hondata intake gasket with high boost? (Hondata)
Does it crush to size and shape? Will it be reusable?
Old Oct 11, 2002 | 10:20 PM
VaporTrail's Avatar
New User
definately reusable, these things are like a god send for a long term motor.
Old Oct 11, 2002 | 10:37 PM
PrecisionH23a's Avatar
Default Re: Hondata intake gasket with high boost? (VaporTrail)
when are you guys gonna have one for the h22 or h23s?
Old Oct 12, 2002 | 12:14 AM
Hayasa15's Avatar
Default Re: Hondata intake gasket with high boost? (GudeH23a)
I just bought one for my z6 and i was told now that they leak and i will need longer studs for it to seal properly. Does anybody know if this is true?
Old Oct 12, 2002 | 01:07 AM
blufke's Avatar
Default Re: Hondata intake gasket with high boost? (Hayasa15)
how much do these gaskets help out performance and other stuff?
Old Oct 12, 2002 | 01:25 AM
SEFIxCivic's Avatar
what do you think of putting some honda bond on the gasket just incase?
Old Oct 12, 2002 | 06:42 AM
earl's Avatar
The only reason you need longer studs is because the gasket is about .1" thicker than stock. You would want to make sure the mani studs were long enough to accept the whole nut.
Old Oct 12, 2002 | 06:44 AM
earl's Avatar
I still don't understand how a gasket that hard will give you good sealing at high boost????
Old Oct 12, 2002 | 07:23 AM
ladysman's Avatar
Is there a particular stud that is needed? I mean from what car and application works with these gaskets. I just got mine and need to install it.
Thanks.
Old Oct 12, 2002 | 08:58 AM
Hayasa15's Avatar
Default Re: Hondata intake gasket with high boost? (ladysman)
where do i get new studs?
Old Oct 12, 2002 | 03:46 PM
VaporTrail's Avatar
New User
they have had them for the h22/23 for a long long time now. Check http://www.hondata.com
I have one on my daily driver Teg, we did not use the washers, which is what necesitates the longer studs. For my all out Civic, I purchased throttle body studs from Acura which thread right in, and are a lot longer.
Old Oct 12, 2002 | 03:47 PM
VaporTrail's Avatar
New User
It's not as hard as you would think it is. It actually becomes somewhat plyable with heat, which is why Hondata recommends retorquing them after a few heat cycles, as they will seat a bit.
Old Oct 25, 2002 | 11:16 AM
Hayasa15's Avatar
thanks vapor trail
Old Nov 1, 2002 | 01:15 PM
integra-modder's Avatar
https://honda-tech.com/zeropost?cmd=reply&id=3172013
Old Nov 1, 2002 | 02:57 PM
earl's Avatar
Default Re: Hondata intake gasket with high boost? (integra-modder)
You should be able to find the studs in any good auto parts store. 1/4" longer should be enough to handle the gasket and the washers.
Dave_Dc2
Nov 30, 2008 05:10 PM
Kr4nG
Apr 4, 2008 12:06 AM
GSR4U2NV
11
May 22, 2005 08:04 PM
RTW DC2R
Feb 11, 2005 10:02 AM
EG3-R
Aug 29, 2002 04:09 AM
