Hondata intake gasket with high boost?
Has anyone used the Hondata heat shield intake gasket with boost of 30 lbs? Since it's made of such a hard material, I'm wondering if it can hold that much pressure. We have one to try but just not sure of it sealing ability.
Re: Hondata intake gasket with high boost? (GudeH23a)
I just bought one for my z6 and i was told now that they leak and i will need longer studs for it to seal properly. Does anybody know if this is true?
Re: Hondata intake gasket with high boost? (Hayasa15)
Re: Hondata intake gasket with high boost? (earl)
I still don't understand how a gasket that hard will give you good sealing at high boost????
The only reason you need longer studs is because the gasket is about .1" thicker than stock. You would want to make sure the mani studs were long enough to accept the whole nut.
Thanks.
New User
they have had them for the h22/23 for a long long time now. Check http://www.hondata.com
I have one on my daily driver Teg, we did not use the washers, which is what necesitates the longer studs. For my all out Civic, I purchased throttle body studs from Acura which thread right in, and are a lot longer.
New User
Re: Hondata intake gasket with high boost? (integra-modder)
You should be able to find the studs in any good auto parts store. 1/4" longer should be enough to handle the gasket and the washers.
RTW DC2R
02-11-2005 10:02 AM
