16th Annual Sports Compact Spring Nationals
Old Apr 17, 2012 | 04:03 PM
EP3Moschini's Avatar
Default 16th Annual Sports Compact Spring Nationals
Heads Up & Index Qualifying:
Saturday, April 28th – 3:00 PM to 8:00 PM
Sunday, April 29th – 10:30 AM
Eliminations: Sunday, April 29th – 2:00 PM
PRICES:
Racer Prices:
PRO RWD Tech Card - $100 (2 Day)
Q32 Tech Card - $100 (2 Day)
Heads Up / Index Class Tech Card - $80 (2 Day)
Test and Tune Tech Card - $30 (Saturday Only)
Bracket Tech Card - $55 (Sunday Only)
Car Show Prices:
Sunday, April 29th – Fully Judged Car Show - $45.00
Spectator Prices:
Saturday - $20.00
Sunday - $25.00
2 Day Spectator Pass - $35.00
HEADS UP & INDEX RACING CLASSES:
Class
Description
Winner
Runner-Up
Semi
Sport FWD
All Brands. 4 cyl. and 6 cyl. "SFWD Trim" Must have 2 front seats and Interior panels required. No rear seats OK. No Gutted out cars permitted. Max Tire 25 x 9.0 Open exhaust OK. Lexan prohibited. Water to Air intercoolers Prohibited 1 piece fronts prohibited. 3 piece fronts OK. 72mm max inducer turbo size (Max 102mm Exd). Up to 2 Power adders allowed (comb ok) Fuel Cell OK - NHRA guidelines MUST be followed. .400 PT, Sportsman Ladder . *Must have 16 cars for full payout.
$1000+ Trophy
$500+ Trophy
$250 + Trophy
Pro Stock
NHRA Rules. Heads-Up Eliminator. .400 Pro Tree. Pro Ladder. FWD Only. (Complete rules available)
$1,000 + Trophy
$500 + Trophy
$250 + Trophy
All Motor
All brands. 4 and 6 cylinder. FWD only. Naturally Aspirated. Lexan ok (front windshield MUST be glass). No 1 piece front ends (3 piece OK). 25" x 9" max slick. Fuel cell ok NHRA requirements MUST be followed! No pro level cars. Gutted interior ok. Open exhaust ok Sportsman ladder. .400 PT. Heads-Up Eliminator. 16 car field. *Must have 16 cars for full payout.Min. HondaweightsHonda:2200lbs- J series 2150lbs - K series, F2K 2000lbs - H series 1900lbs - B series All other cars-2000 lbs
$800 + Trophy
$400 + Trophy
$200 + Trophy
10.50 Index
Open to all Import/Sport Compact Cars. Any Combination allowed at any weight. No Throttle Stops or Delay Boxes allowed. No Sandbagging. NHRA safety rules apply. All Run Field .400 Pro Tree, No DeepStaging allowed. Sportsman Ladder. Must have 16 cars for full payout.
$600 + Trophy
$300 + Trophy
$150 + Trophy
11.50 Index
Open to all Import/Sport Compact Cars. Any Combination allowed at any weight. No Throttle Stops or Delay Boxes allowed. NHRA safety rules apply. 16 Car Field. All Run Field .400 Pro Tree, No DeepStaging allowed. Sportsman Ladder. Must have 16 cars for full payout.
$600 + Trophy
$300 + Trophy
$150 + Trophy
Qualifying on Saturday & Sunday with Heads Up & Index Classes – Eliminations Sunday after Qualifying.
Class
Description
Winner
Runner-Up
Semi
1/4s
Quick 32*
6.00 to 11.49: Open to AWD, RWD, FWD Hot Rod Pro FWD trim only. Rotary and 4, 6 cyl import/domestic sport compact motors ok, import V8 power plants ok (ie. Toyota, Nissan). NHRA safety equipment required. No year limitation on full tube chassis or back half. .500 Full Tree, Bracket Style Eliminator . 32 Car Field. Payout based 32 Car Field. Payout adjusted if field is not full.
$2,000 + Trophy
$1,000 + Trophy
$500 + Trophy
$250
Pro RWD
Open to all RWD 3/4 and full chassis sport compact vehicles. Open to all 4 and 6 cylinder and rotary power plants. Heads up, pro tree. Pro ladder Maximum displacement: 6 cylinder: 4.0L. Maximum two power adders allowed-Minimum weights: 4 cylinder/2 rotor: 2000 lbs (over 3.0 liter add 200 lbs) 3 rotor: 2200 lbs 6 cyl: 2400 lbs *3/4 chassis- deduct 100 lbs*3/4 chassis must retain original firewall, OEM front shock towers and frame rails in front of the firewall. Front Struts must mount to as-built upper OEM location. Final strut installation must be in a manner such that removing the bolts on top of the strut tower allows strut assembly removal to be considered a 3/4 chassis.
$2,000 + Trophy
$1,000 + Trophy
$500 + Trophy
$250
Bracket Classes – Sunday, April 29th
Bracket 1 (B1)
12.99 seconds & Quicker - All Run, .500 Full Tree, Bracket Style Eliminator. *Must have 32 cars for full payout.
$600 + Trophy
$300 + Trophy
$100 + Trophy
Bracket 2 (B2)
13.00 seconds & Slower - All Run, .500 Full Tree, Bracket Style Eliminator. *Must have 32 cars for full payout.
$400 + Trophy
$200 + Trophy
$50 + Trophy
Car Show Information: who cares
Old Apr 19, 2012 | 05:39 PM
EfGsrTurboHatch's Avatar
Default Re: 16th Annual Sports Compact Spring Nationals
sounds like it will be a fun weekend
Old Apr 20, 2012 | 03:06 AM
I am astonished no one is talking in this thread
Old Apr 20, 2012 | 04:20 AM
MARC P's Avatar
GP1 Racing will be there with 3 cars.
Old Apr 20, 2012 | 06:42 AM
CHEETAH's Avatar
Motor
Am I the only one not paying attn? did they increase all motor wight to 2000 lbs?
in the OGS point series thread it was:
Honda:
2200lbs - J series
2150lbs - K and F2K Series - 2.7L Max Displacement
2000lbs - H and H2B Series- 2.7L Max Displacement
1900lbs - B Series- 2.7L Max displacement
please confirm...
Old Apr 20, 2012 | 06:48 AM
BILLY_BAD_A$$'s Avatar
I can't wait. I should have my car fixed over the weekend and hopefully put up my 1st 8.xx
Old Apr 20, 2012 | 06:50 AM
AROD's Avatar
if you figuer out the track
Old Apr 20, 2012 | 06:56 AM
2.6lrex's Avatar
we are leaving at 8 am fri morning to roll out. Cant wait for this event
Old Apr 20, 2012 | 06:58 AM
Etown is a good track and I have a great tuner so as long as the car doesn't act stupid, I'm confident it can happen. I gotta do something impressive if I plan on beating these front runners
Old Apr 20, 2012 | 07:00 AM
AROD's Avatar
should be fine you have the same turbo that all the front runner have!
Old Apr 20, 2012 | 07:49 AM
E Town DSM's Avatar
well be there hopefully we wont be oiling the track down this time. i thought the front runners have 372's?
Old Apr 20, 2012 | 08:08 AM
j-bird20's Avatar
The required catch pans are supposed to stop that...no?
Old Apr 20, 2012 | 08:25 AM
allmotorhatch's Avatar
Not when you blow the catch pan straight off.
Old Apr 20, 2012 | 09:46 AM
AROD's Avatar
LOL…nooo I’m one of the regulars, I can’t keep up with that 2.8sec back half billet stuff..LOL
Old Apr 20, 2012 | 10:19 AM
nonvtecallmotor's Avatar
I'm going testing tonight so that I make sure what happened at Honda Day never happens again...
If all goes well. I'm down like Charlie Brown...
Old Apr 20, 2012 | 12:07 PM
E Town DSM's Avatar
Good stuff rick was hoping you would of won so i could of claimed my 10 percent fee i negotiated with tuna lol.
Yea my last catch pan was a epic fail got a new one though
Old Apr 20, 2012 | 01:35 PM
I don't even remember them checking our catch pan @ Honda Day
Old Apr 20, 2012 | 02:02 PM
j-bird20's Avatar
I will make sure someone looks at mine. Im not goin through tech without them lookin at it.
Old Apr 20, 2012 | 02:13 PM
MARC P's Avatar
Honda:
2200lbs - J series
please confirm...
Looks the same to me
Old Apr 20, 2012 | 03:44 PM
Garage 808 Hatch's Avatar
Honda:
2200lbs - J series
please confirm...
You're just reading it wrong, they listed the weight 1st, and then the combo it is for. It is the same
Old Apr 20, 2012 | 10:44 PM
I would of gladly gave you 10% if I would of won lol. Thanks again!! A $1
part caused my issue, but Its all better now.
Old Apr 21, 2012 | 03:29 AM
E Town DSM's Avatar
So i heard its always the dumb **** see you next weekend
MR. BAKERZMAN
Northeast
Jun 25, 2012 04:33 PM
K20A2-t
Jul 5, 2010 08:19 PM
